Author Topic: Local Path in Documentation  (Read 2602 times)
MikeRes
« on: October 14, 2015, 08:32:18 pm »
I'm pretty new to this all and looking for some help. I have defined a local path (FOLDER) representing a directory. This is used as part of a path in a related file for a use case.
When I use the local path as part of the location of a file on the Files tab of the use case property window (e.g. %FOLDER%\File.docx)  it works fine i.e. when I click launch the correct file is opened.
However when I generate the documentation for the use case the local path in not replaced and shows %FOLDER% instead.
Any ideas on how to get the documentation to use the defined local path?
Mike
« Last Edit: October 14, 2015, 08:35:17 pm by mpoelzl »
