Author Topic: FRQ: populate diagram  (Read 7047 times)
angel-o-sphere
« on: May 14, 2004, 07:39:06 am »
I like to be able to do this:
Create new diagram
Drop one element A from a arbitrary folder
right click on the element
follow a new entry called "populate"
follow that entry into "links-from", "links-to" or "elements"
e.g. choose from "links-to" "realisation" and all elements which are linked *from* A via a "realization" link should pop up on the diagram.
e.g. choose from "elements" and all linked element types show up in a pop up menue and you an e.g. select "use case" and all use cases linked to A are popping up.
This is a very powerfull feature, hope you can add it in some future.
  angel'o'sphere
Bruno.Cossi
Re: FRQ: populate diagram
« Reply #1 on: May 14, 2004, 11:03:16 am »
this already exists in EA - right click the element as select "Insert Related Elements". Using the options in the next window, you can achieve all of what you have described.
And I agree, this is a powerful feature! :-)
Bruno
angel-o-sphere
« Reply #2 on: May 17, 2004, 01:18:14 am »
Ah, cool.
Most of teh time I use a 3.6 version of EA at work ... at home I have the 4.0, will check that later :D
Angelo
Bruno.Cossi
« Reply #3 on: May 17, 2004, 04:17:23 am »
I loved EA 3.60 but I REALLY love 4.0 :-) Many little things that I would have wished for appeared in EA 4.0, I am still uncovering them... many nice surprises!
Bruno
