Author Topic: extend target activation  (Read 10473 times)
andro
« on: December 14, 2004, 07:05:25 am »
In EA Build 743, when editing properties of a message on a sequence diagram, there are three properties that can be turned on/off. These are:
- extend source activation,
- end source activation,
- end target activation.
There's no "extend target activation". Why?
andro
Re: extend target activation
« Reply #1 on: December 14, 2004, 08:08:09 am »
If you can give a meaningful answer to what this should mean, Sparx might think it over  ;)
andro
« Reply #2 on: December 14, 2004, 01:25:17 pm »
I just wanted to make a simple drawing to show that a server serves two requests simultanously.  Send me your address to [email protected] and I'll send you the pic.
I guess you will tell me that I violated the concept of sequence diagrams somehow, but when I aksed once at this forum why EA lets do different things that make absolutely no sense, I got the repsonse that EA is just a tool and it's only up to the user to use it wisely.
andro.
« Reply #3 on: December 14, 2004, 02:53:01 pm »
Andro, I'll have a look tomorrow (time to sleep  :))
mchiuminatto
« Reply #4 on: December 14, 2004, 06:32:51 pm »
easy, easy!!!  :o , you can better model it using a Par combined fragment. Check Superstructure, page 410 and 411 (an example)
Regards.
Marcello
mbc
  • Embedded software developer
« Reply #5 on: December 15, 2004, 12:25:07 am »
Andro,
I have had problems with this too, and together with Sparx support I reached the conclusion that it is not currently possible. They promised to think about a solution.
mchiuminatto,
The par fragment doesn't solve the problems that this situation causes with the focus rectangles.
Mikkel
andro
« Reply #6 on: December 15, 2004, 07:20:47 am »
I can't see how the diagram from the Superstucture could help me. Here's my problem. The first diagram looks OK:
And the second doesn't:
I produced the second diagram by moving up a single message, namely: the message Caller II -> Operator. As I said, I wanted to show that two services take place in paralell.
Andro.
