Author Topic: EA crash when losing network connectivity.  (Read 4218 times)
mpolo
« on: January 24, 2005, 09:49:21 am »
Steps to reproduce:
connect to a SQLServer2000 repository
unplug network access
plug back in. (after 1-2 minutes)
try to save work in progress.
You receive:
Microsoft OLEDB Provider for SQL Server -2147467259
Connection Failure.
Then
EA has experienced a network error and will close down.
Then
The instruction at X referenced memeory at 0x00..004 Click ok to terminate (GPF)
This is not good if using a wireless adapter!
Michael
Re: EA crash when losing network connectivity.
« Reply #1 on: January 24, 2005, 10:07:19 am »
Guess you should mail this to Microsoft  ;D
mikewhit
  • Accessing ....
« Reply #2 on: January 25, 2005, 12:28:17 am »
Have you tried this with any other OLEDB apps to the same server ?
As Thomas says, it may well be a problem with that library rather than EA.
Also check the Microsoft Knowledge Base website with relevant keywords, there may be an issue reported there.
