Author Topic: Update Repository  (Read 4492 times)
federicoha
Update Repository
« on: April 25, 2005, 08:27:15 am »
Hi:
I have a simple question about your excelente app.
When update (i mean put all the repository) in a MSSQL database, a warning message say:
Caution:
All data will be erased from the Target Model prior to data transfer. Please ensure you have backed up target if
neccesary.
Ok. When i want to update de repository (with some changes) EA update all repository, so:
Person A, Person B
+. A do some changes and at the same time B do the same.
+. A update the repository and B not. When B update the repository, A lost her changes.
So, the update is not incremental.
A tell B that update the repository, but when B get the repository, lost the actual changes.
Is there in analisys of EA, update of the repository in incremental way?
When we see this simple scenario, have a problem in a group of developers.
Or, worst, EA have that funcionality and we don't see it?
Thanks in advance.
Regards.
Federico.
Bruno.Cossi
Re: Update Repository
« Reply #1 on: April 25, 2005, 10:16:34 am »
Hi Federico,
it sounds like you are using the Data Transfer functionality which indeed does just that - moves the whole contents of the repository into another one, overwriting the original contents. What you probably are looking for is a replication - see menu items under Tools > Manage .EAP file.
Also, if all of your users are on a common network, you may want to look into having the users share the same repository, it would make your life likely much easier.
Hope this helps!
Bruno
federicoha
« Reply #2 on: April 25, 2005, 02:30:53 pm »
Hi Federico,
Hope this helps!
Bruno
really...
thanks for your answer
is my fault not read all de docs to see that feature
thanks again...
Federico.
Bruno.Cossi
« Reply #3 on: April 25, 2005, 03:56:40 pm »
No problem Federico, the documentation can sometimes be a bit confusing. Happy to help!
Bruno
really...
thanks again...
Federico.
