Author Topic: XML Schema Generation  (Read 8561 times)
Oliver Michalski
« on: November 14, 2006, 04:53:01 am »
I would like to introduce Sparx Enterprise Architect as standard for the modelling at my new company but I have some problems generating xml schemas. Our requirement is to rebuild huge schemas offered by standardization institutions for use with  Microsoft BizTalk Server 2006 as a Business Process Engine . In some cases we can not rebuild the schemas
Ok what is the problem:
We need that we can manipulate the multiplicity of a Choice or Sequenze in the Stereotype XSDComplexType. In the class declaration we can give the class a multiplicity , but if we want to generated the XML Schema this information are omitted.  :-[
If we  alternatively work with associations between classes we have  a further problem.The problem with the associations is that we can not manipulate the order. Our  associations are sometimes at the beginning and sometime at the end. But for validation it is important that the tags are in the right order.  :'(
Any Suggestion?
Oliver :)
Re: XML Schema Generation
« Reply #1 on: November 14, 2006, 05:51:22 am »
This is almost certainly something Sparx should look at in detail.
If you've not done so already, report this through the bug report page. You can reach it from the EA main menu via Help | On-line Resources | Bug Report Page.
Attach a copy of the offending schema, and perhaps the model or other source you started with - zipped for ease of handling.
Sparx has said they are working on at least one other XSD issue, so this is the right time to bring this forward.
Oliver Michalski
« Reply #2 on: November 14, 2006, 06:33:40 am »
Hi Midnight,
thanks for your answer. I have send a Bug Report.
Oliver  :)
henmanworking
« Reply #3 on: November 21, 2006, 03:03:01 am »
Hallo Olmich,
I have the same problem. Have you anything heared, when the bug is fixed?
Henry
