Author Topic: Suggestion: Diagram Hyperlinks should show type  (Read 4953 times)
darren.sampson
« on: January 08, 2007, 07:55:20 pm »
Hi Everyone,
I've just been playing with diagram hyperlinks and it occurred to me that it would be helpful if the hyperlink glyph actually indicated the type of diagram.
This should be simple - the glyph used in the project browser would be perfectly adequate.
Comments? Votes?
Darren.
See the new Jobs Section on:EA Wiki...
Re: Suggestion: Diagram Hyperlinks should show typ
« Reply #1 on: January 08, 2007, 08:38:19 pm »
Just to add some additional information to Darren's point...
The hyperlink address is static.  That is, in the properties box the Hyperlink address control is NOT actually linked to the diagram that the hyperlink attaches to.  Thus, if you change the name of the linked diagram, the address doesn't change.
The hyperlink element is both a link and an element.  This can be shown by copying and pasting into multiple diagrams.  If you change the note in one diagram, it changes in the other one(s).
Accordingly, the name of the addressed diagram should be displayed separately from the notes field (which should be like the notes field of any other element).  In this way, it could be updated as the source diagram name changes.  The notes control would therefore, by default, be empty consistent with other elements.
BUG: The Alias field doesn't work if you select [X] Use Alias if Available in the diagram properties dialog.
By exposing the Name property one could add the following radio buttons: (and this could be made consistent across all the diagram linkage mechanisms):
(  ) Override linked name with supplied - if blank (default) then name is suppressed
(X) Use linked name - (default) control is disabled and populated from the source diagram.
Consideration should be given to making the hyperlinks be visible on the browser (like Diagram Frames and References)
With these changes, Diagram Hyperlinks would be even more useful...
[size=0]©2007 Paolo Cantoni & Darren Sampson, Ripple Systems[/size]
« Reply #2 on: January 09, 2007, 08:19:47 am »
Add my vote for both Darren's and Paolo's suggestions.
darren.sampson
« Reply #3 on: January 10, 2007, 04:07:10 pm »
Hi Darren,
have you already looked here?
I take it you meant to post that here as Simon suggests. I'd agree with the other thread too - why not kill two birds with one stone?
« Last Edit: January 10, 2007, 04:07:44 pm by darren.sampson »
