Author Topic: Set attribute initial value on Transformation  (Read 4732 times)
da_Burp
« on: June 20, 2007, 10:53:47 pm »
On a model transformation i;m generating ID's for classes, and i would like to set the initial value of that id to -1. But it seems like I can not set the 'initial' value of an attribute on transformation of a model. I can access all the other fields like name, notes, alias etc.. But why on earth can't I set the initial field?
Am I just using the wrong name(initial)? Or is it, for some odd reason, simple not possible to do so?
« Last Edit: June 20, 2007, 10:54:02 pm by da_Burp »
Re: Set attribute initial value on Transformation
« Reply #1 on: June 21, 2007, 01:15:44 pm »
You're using the wrong name, you need to use default.
See http://www.sparxsystems.com.au/EAUserGuide/index.html?transformingobjects.htm.
da_Burp
« Reply #2 on: June 21, 2007, 08:58:01 pm »
Thanks. I realize I never found this helpitem because I have never used the contents to find helpitems. ::)
