Author Topic: Double-Clicking for navigation  (Read 6456 times)
« on: July 05, 2005, 08:39:53 pm »
I (and others) have mentioned the UI design issues with EA.
One thing that is really starting to bite (me) is the overloading of double-click for both opening the item specification and for navigating in the case of the (misnamed) composite item.
Initially, I didn't have many Element-linked-diagrams, so I didn't appreciate the scope (to me) of the problem.
Element-linked-diagrams (in my opinion) are a terrific idea and (therefore) I'm using them (pretty-much) everywhere. 8)
The use of Double-Click for automatically navigating to the linked Diagram is also a terrific idea! 8)
The problem occurs in the fact that when I Double-Click on a non-linked Element, I get the properties (so my brain - like Homer Simpson's - matches - Ummm... Double-Click <-> Properties).  In fact, depending on where in the UI I Double-Click, even for a linked Element, I will always get Element properties.
However, on the Diagram if I Double-Click a linked Element, I navigate to the Diagram.  My brain (and Homer's, if he used, EA ;)) goes: DOH!...
My suggestion is, given that we are expressly talking about mouse movements, that Double-Clicking on a linked Element, anywhere other than the "link" icon (o-o) will bring up the properties and Double-Clicking on the "link" icon will navigate.
Thoughts?
Re: Double-Clicking for navigation
« Reply #1 on: July 06, 2005, 02:39:00 am »
It took a while until I realized what you mean with (o-o) :-[ It's the infinity symbol that appears for the so-called Composite elements.  Probably a good idea and not too difficult to implement. Maybe an option to turn on this navigation behaviour would be fine?
« Last Edit: July 06, 2005, 02:44:03 am by thomaskilian »
« Reply #2 on: July 06, 2005, 03:43:40 am »
Thomas,
I thought it was a chain (linking...)  ;)  Hence o-o...
Well, for my part, I don't want to turn off the navigation, I just want to be able to better control when I get navigation or not.  Perhaps if the link symbol were more prominent and its location changed - at present it can get overlayed by other stuff.  The top left of the box doesn't seem to be used...
I don't mind an option to turn off navigation, in fact I thought there was, but I couldn't easily find it.  Maybe it was the Lithuanian product...
« Reply #3 on: July 06, 2005, 05:34:39 am »
I was refering to the "Double Click in Browser" in General Options.  Maybe you're right when refering to the o-o as a chain. But it could also be eyeglasses ;D
« Reply #4 on: July 06, 2005, 05:53:38 am »
I was referring to the "Double Click in Browser" in General Options.
Ah... that's what I was thinking about...
Maybe you're right when referring to the o-o as a chain. But it could also be eyeglasses ;D
Now you're talking!  Colour in the o's (to make them John Lennon sunnies and...
"You say you want a navi-gation
Well, you know
We all want to change the model" ;D
(with apologies to JL...)
« Reply #5 on: August 31, 2007, 03:31:30 am »
Bump - to raise the profile of this issue again...
The following new proposal has been added: [size=13]Attaching diagrams to elements[/size] which is related to this post.
Related posts are to be found in: [size=13]Re: shape scripting/element properties[/size], [size=13]Double-Clicking for navigation[/size] and, perhaps most tellingly in: [size=13]Re: Default Diagram[/size] and [size=13]TIP: Adding Diagram to Interface element[/size]!
« Reply #6 on: August 31, 2007, 10:48:25 am »
And once more, once more...
