Author Topic: Search Based on Diagram Selected  (Read 17935 times)
wikitect
    • TRAK Community
« on: December 14, 2009, 07:20:12 pm »
Searches are necessary when using  EA for enterprise architecture as often there is a stronger emphasis on discovering and presenting relationships between classes. In EA relationships are the second class citizens (poor relations ;)) in EA e.g. not appearing in the normal searches, not having the same fields (an Alias for a connector is shoe-horned into a StyleEx field along with all sorts of other things).
Similarly the matrix view of a diagram only lists the classes not the relationships between classes for the diagram so that isn't very helpful.
Whilst I can create a SQL query that lists the objects and relationships between them what EA won't allow me to do is to base the query on the diagram that is selected in the catalogue.  If it did then EA could be used to present the matrix equivalent of a diagram with relationships - essential for architecture frameworks.
Of course the next part of the problem is that EA doesn't provide the means to export search results as a CSV (unlike the relationship matrix).
Favourite epitaph: 'Under this sod lies another'
TRAK Framework https://sf.net/p/trak
MDG for TRAK https://sf.net/p/mdgfortrak
Re: Search Based on Diagram Selected
« Reply #1 on: December 14, 2009, 07:33:25 pm »
I think there is something like an addin-search as well.
Maybe that can be used to search based on the selected diagram?
« Reply #2 on: December 15, 2009, 12:12:45 am »
Geert,
I think the big problem is that while arcs are second class citizens, diagram links are third class.  We've already alluded in other topics that there's no collection diagram.DiagramLinks.
As a consequence, there is NO guarantee that for each link are that is visible in the diagram, there is an associated t_DiagramLinks row.
The search may or may not return the right number of rows.
fwoolz
« Reply #3 on: December 17, 2009, 09:46:26 am »
I seem to recall some discussions a while back about how badly the EA schema is is need of an overhaul  ;) ...
Fred Woolsey
Interfleet Technology Inc.
mrf
« Reply #4 on: December 17, 2009, 01:19:14 pm »
Hi wikitect, I've created an EA JScript (version 7.5+ is required) that lists all connectors on a diagram in the search window. Hopefully it should satisfy your requirements.
I'm just sorting out my access to the community site, so it should be available from there in an hour or two.
PS: In the future we plan on listing scripts flagged as "Project Browser" scripts in the Project Browser context menu, so that they can be accessed conveniently.
« Last Edit: December 17, 2009, 01:19:44 pm by mfraser »
Best Regards,
Michael
mrf
« Reply #5 on: December 18, 2009, 01:43:23 pm »
PPS: Looks like the script is taking a while to get through the review process for the community site, so I'll post it here.
Please note that due to the 5k word limit I've had to split it over a few posts.
Part 1 of 2
 * Script Name: ListDiagramConnectors
 * Author: Michael Fraser (Sparx Systems)
 * Purpose: Lists relationships between objects that appear on the diagram that is
 * currently selected in the project browser
 * Date: 2009-12-17
//  GLOBAL DEFINITIONS
var DIAGRAM_OT            = 8;
// The columns that will appear in the Model Search window
var SEARCH_SPECIFICATION = "<ReportViewData>" +
                                          "<Fields>" +
                                          "<Field name=\"CLASSGUID\" />" +
                                          "<Field name=\"CLASSTYPE\" />" +
                                          "<Field name=\"Client\" />" +
                                          "<Field name=\"Supplier\" />" +
                                          "<Field name=\"Direction\" />" +
                                          "<Field name=\"Name\" />" +
                                          "<Field name=\"Notes\" />" +
                                          "<Field name=\"Client Aggregation\" />" +
                                          "<Field name=\"Client Cardinality\" />" +
                                          "<Field name=\"Client Role\" />" +
                                          "<Field name=\"Supplier Aggregation\" />" +
                                          "<Field name=\"Supplier Cardinality\" />" +
                                          "<Field name=\"Supplier Role\" />" +
                                          "</Fields>" +
                                          "<Rows/>" +
                                          "</ReportViewData>";
 * Main function
function ListDiagramConnectors()
      Repository.EnsureOutputVisible( "Script" );
      Session.Output( "JScript: List Diagram Relationships" );
      Session.Output( "=========================================" );
      // Get the type of element selected in the Project Browser
      var treeSelectedType = Repository.GetTreeSelectedItemType();
      // Handling Code
      switch ( treeSelectedType )
            case DIAGRAM_OT:
                  // Code for when a diagram is selected
                  var theDiagram as EA.Diagram;
                  theDiagram = Repository.GetTreeSelectedObject();
                  // Create a DOM object to represent the search tree
                  var xmlDOM = new ActiveXObject( "MSXML2.DOMDocument.4.0" );
                  xmlDOM.validateOnParse = false;
                  xmlDOM.async = false;
                  Session.Output( "Working on diagram '" + theDiagram.Name + "' (Type=" +
                  theDiagram.Type + ", ID=" + theDiagram.DiagramID + ")" );
                  // Load the search template
                  if( xmlDOM.loadXML(SEARCH_SPECIFICATION) )
                        // Resolve the results node in the xml template
                        var node = xmlDOM.selectSingleNode( "//ReportViewData//Rows" );
                        // A connector has a one to many relationship with diagram (eg one connector
                        // may appear on many diagrams). The DiagramLink object represents an instance
                        // of a connector on a single diagram, and contains properties such as its
                        // geometry, visibility etc.
                        // Get all diagramLinks for this diagram
                        var diagramLinks as EA.Collection;
                        diagramLinks = theDiagram.DiagramLinks;
                        for ( var i = 0 ; i < diagramLinks.Count ; i++ )
                              // Get the current diagram link
                              var currentLink as EA.DiagramLink;
                              currentLink = diagramLinks.GetAt( i );
                              // Load the corresponding connector object for the link
                              var correspondingConnector as EA.Connector;
                              correspondingConnector = Repository.GetConnectorByID( currentLink.ConnectorID );
                              // Add the connector's details to the search data
                              AddRow( xmlDOM, node, correspondingConnector );
                        // Fill the Model Search window with the results
                        Repository.RunModelSearch( "", "", "", xmlDOM.xml );
                  else
                        Session.Prompt( "Failed to load search xml", 0 );
                  break;
            default:
                  // Error message
                  Session.Prompt( "This script does not support items of this type.", 0 );
      Session.Output( "Done!" );
« Last Edit: December 18, 2009, 04:19:05 pm by mfraser »
Best Regards,
Michael
mrf
« Reply #6 on: December 18, 2009, 04:17:43 pm »
Part 2 of 2:
 * Adds an entry for the method object 'theRelationship' to the xml row node 'rowsNode'
function AddRow( xmlDOM, rowsNode, theRelationship )
      // Cast theMethod for intellisense
      var relationship as EA.Connector;
      relationship = theRelationship;
      // Create a Row node
      var row = xmlDOM.createElement( "Row" );
      // Get client details for the connector
      var client as EA.Element;
      var clientEnd as EA.ConnectorEnd;
      client = Repository.GetElementByID( relationship.ClientID );
      clientEnd = relationship.ClientEnd;
      // Get supplier details for the connector
      var supplier as EA.Element;
      var supplierEnd as EA.ConnectorEnd;
      supplier = Repository.GetElementByID( relationship.SupplierID );
      supplierEnd = relationship.SupplierEnd;
      // Add the Model Search row data to our DOM
      AddField( xmlDOM, row, "CLASSGUID", relationship.ConnectorGUID );
      AddField( xmlDOM, row, "CLASSTYPE", "connector" );
      AddField( xmlDOM, row, "Client", client.Name );
      AddField( xmlDOM, row, "Client", supplier.Name );
      AddField( xmlDOM, row, "Direction", relationship.Direction );
      AddField( xmlDOM, row, "Name", relationship.Name );
      AddField( xmlDOM, row, "Notes", relationship.Notes );
      AddField( xmlDOM, row, "Client Aggregation", clientEnd.Aggregation );
      AddField( xmlDOM, row, "Client Cardinality", clientEnd.Cardinality );
      AddField( xmlDOM, row, "Client Role", clientEnd.Role );
      AddField( xmlDOM, row, "Supplier Aggregation", supplierEnd.Aggregation );
      AddField( xmlDOM, row, "Supplier Cardinality", supplierEnd.Cardinality );
      AddField( xmlDOM, row, "Supplier Role", supplierEnd.Role );
      // Append the newly created row node to the rows node
      rowsNode.appendChild( row );
 * Adds an Element to our DOM called Field which makes up the Row data for the Model Search window.
 * <Field name "" value ""/>
function AddField( xmlDOM, row, name, value )
      var fieldNode = xmlDOM.createElement( "Field" );
      // Create first attribute for the name
      var nameAttribute = xmlDOM.createAttribute( "name" );
      nameAttribute.value = name;
      fieldNode.attributes.setNamedItem( nameAttribute );
      // Create second attribute for the value
      var valueAttribute = xmlDOM.createAttribute( "value" );
      valueAttribute.value = value;
      fieldNode.attributes.setNamedItem( valueAttribute );
      // Append the fieldNode
      row.appendChild( fieldNode );
ListDiagramConnectors();
« Last Edit: December 18, 2009, 04:19:20 pm by mfraser »
Best Regards,
Michael
wikitect
    • TRAK Community
« Reply #7 on: December 18, 2009, 11:35:15 pm »
Thanks for this.
Will have to have a play later and see what happens.
What I was trying to list was
for the visible connectors of a particular stereotype
    [* source object attributes - name, alias]
    [* connector attributes - name, alias, notes, direction]
    [* target object attributes - name, alias]
    in order to represent / characterise 'interfaces' (flows of data, energy, materiel)
    No doubt some good pickings to be had once I figure out what's going on in the script - not something I've touched in EA yet.
    Anyway, good stuff!
    Now on to the next suggestion/request wrt relationships .... import...
    [/list]
    Thelonius
    • I think. Therefore I get paid.
    « Reply #8 on: December 19, 2009, 11:48:22 am »
    Michael - thanks for the script. I got it to run - small step for others but a major leap forward in my learning curve for EA scripting.
    Just interested - would it be possible to distinguish - through code - the "visible" connectors from all connectors on a diagram?
    mrf
    « Reply #9 on: December 21, 2009, 08:44:36 am »
    When interpreting the script, it is important to understand the role of the DiagramLink object. A connector has a one to many relationship with diagram (eg one connector may appear on many diagrams). Whereas a Connector object describes the relationship between two entities, the DiagramLink object represents an instance of a connector on a single diagram, and contains properties such as its geometry, visibility etc.
    If it helps, a basic psuedocode of the script would be as such:
    START
    Construct an XML document that will be sent to the search window (This document will describe both the headings and the data that will be displayed)
    Find the currently selected item in the tree
    If it's a diagram:
        Get the collection of diagramlinks for the diagram
        For each diagramlink in the diagram
            Get the corresponding connector object for the diagramlink
            Add the connector's details to the search data (AddRow function)
    Send the search data to the search window and display the results.
    END
    @wikitect
    If you want to add/remove what data is displayed in the search report you must change two things:
    1. The XML search template provided in the variable SEARCH_SPECIFICATION (this defines which headings are included in the search window).
    2. The script method AddRow (this contains the logic for how the fields are populated). Currently it displays various bits of data for the Connector, Source and Target Objects. Each of these objects has autocomplete intellisense available, so you should easily be able to get a list of what data is available to you. If not, check out the Enterprise Architect SDK for Connectors (http://www.sparxsystems.com/uml_tool_guide/sdk_for_enterprise_architect/connector2_2.html) and Elements (http://www.sparxsystems.com/uml_tool_guide/sdk_for_enterprise_architect/element2.html).
    @wikitect and Thelonius
    As was mentioned above, the DiagramLink object describes an instance of a Connector on a diagram. The DiagramLink object (http://www.sparxsystems.com/uml_tool_guide/sdk_for_enterprise_architect/diagramlinks.html) has a property called IsHidden which can be used to test whether the Connector is visible on the provided diagram. Therefore you could change the code at around line 88 to the following:
    // Only process the diagram link if it is visible on the diagram.
    if ( !currentLink.IsHidden )
    I hope that helps, if you have any further questions, don't be afraid to ask!  8-)
    « Last Edit: December 21, 2009, 08:54:55 am by mfraser »
    Best Regards,
    Michael
    « Reply #10 on: December 21, 2009, 09:17:07 am »
    [size=18]...[/size]
    [size=18]...[/size]
    Michael,
    Does that mean we're NOW guaranteed that there will exist a DiagramLink for every possible connector on the Diagram?  I thought that even recently that STILL wasn't the case?
    Last time it was mentioned, within the last two months by Neil I think, he still admitted that a DiagramLink may not exist if you haven't done something to the connector to change it from the default.
    I'd like to get a definitive answer (for build 850 at least).
    mrf
    « Reply #11 on: December 21, 2009, 09:32:11 am »
    I've just had that chat with Neil myself and it turns out that I was misinformed. From what I understand now, the DiagramLinks collection won't have an entry for Connectors on the diagram that haven't been modified beyond their default settings.
    We've had a chat about this, and came to the consensus that the DiagramLinks collection should contain all connector instances on the diagram, regardless of whether they are using their default settings or not. We came up with a fairly simple way to achieve this, so I'll look at getting it implemented ASAP.
    Best Regards,
    Michael
    « Reply #12 on: December 21, 2009, 10:01:14 am »
    Thanks, Michael,
    It's only taken 3 years...
    Does that mean you'll also be able to implement a DiagramObject.DiagramLinks collection as mentioned in Need DiagramObject.DiagramLinks collection?
    mrf
    « Reply #13 on: December 21, 2009, 10:18:34 am »
    At first glance I can't see why not, but I'd really need to chat to those who have said it can't be done and get a better understanding as to how they got to that opinion.
    So I wouldn't rule it out for the future, but for the short term, "No, you can't have it" (Midnight, 2009).
    Best Regards,
    Michael
