Author Topic: script detecting connectors ?  (Read 17483 times)
utilisateurEA
« on: March 26, 2010, 02:05:39 am »
I would like to write a script in C# detecting every links (for example an association link) in my project, and their target.
I’ve found on the EA website an example describing how to find every tagged values and tried to adapt it for my case, but it doesn’t work.
I tried the following code :
String printedText="";
                    EA.Package aPackage;
                    aPackage = Repository.GetTreeSelectedPackage();
                    foreach (EA.Connector connect in aPackage.Connectors)
                        printedText = printedText + connect.ClientEnd.End + ",";
but nothing is printed when I display « printedText ».
I think I don’t even excecute the loop 1 time because if I write
                        printedText = “test”;
I have exactly the same result: nothing.
Do you have an idea to solve this problem ?
Thank you.
Re: script detecting connectors ?
« Reply #1 on: March 26, 2010, 08:43:52 am »
I've only ever used Element.Connectors, not Package.Connectors.
« Reply #2 on: March 26, 2010, 12:41:18 pm »
Has anybody ever used Package.Connectors?
Did it work?
utilisateurEA
« Reply #3 on: March 26, 2010, 07:20:07 pm »
Indeed the result is better with Element.Connector.
Package.Connector didn't identify anything in my project (but maybe I have not the adapted objects)
Do you know how to hobtain the name of the target of the link ?
Because in Connector properties there are"ClientID" and "ClientEnd" but there is nothing in CleintEnd giving the name of the target.
(I have an idea using ClientID and then using it to find the name of the target, but there is surely a simpler method) ?
« Reply #4 on: March 26, 2010, 07:34:50 pm »
Use Repository.GetElementByID to get the element the connector is pointing to.
(not there is no simpler way)
utilisateurEA
« Reply #5 on: March 26, 2010, 08:13:54 pm »
OK thanks,
But what happen if the target is an operation or an attribute ? It will probably give the ID of the class containing the operation and not the ID of the operation ??
« Last Edit: March 26, 2010, 08:14:14 pm by utilisateurEA »
beginner
« Reply #6 on: March 26, 2010, 08:35:04 pm »
You can not have a connector to attributes or operations.
b.
utilisateurEA
« Reply #7 on: March 26, 2010, 08:51:38 pm »
In fact yes : it is possible to have a "generalize" link between a class and an operation, and even between 2 operations (you have to make a right click "link to element feature")
« Reply #8 on: March 26, 2010, 09:09:31 pm »
You have to be careful...  The linkage is (effectively) a rendering ONLY.  The t_connector details - as beginner says - ONLY refer to the end Elements (not Features).  It is NOT a simple matter to extract the rendering information and convert it to the (derived) Feature linkages.
beginner
« Reply #9 on: March 26, 2010, 09:10:14 pm »
You're right, but that's still a link between elements. I do not know where they store the "Linked Element" information. Probably in the MiscData as this feature had been added in a later release of EA.
b.
P.S. Just checked in the database that at least half a dozen fields in the connector are changed with the Link Element and most of them are not available via the API.
« Last Edit: March 26, 2010, 09:25:02 pm by beginner »
utilisateurEA
« Reply #10 on: March 26, 2010, 09:46:16 pm »
how could you access to  the MiscData informations of a connector ? I used get_MiscData but obtained nothing ?
« Reply #11 on: March 26, 2010, 09:46:53 pm »
There was a topic a few weeks ago about this "link to element" feature and how it is stored in the database.
Use the search button on the top left to try and find it.
beginner
« Reply #12 on: March 26, 2010, 10:32:45 pm »
I emphasized the relevant part.
b.
« Reply #13 on: March 26, 2010, 10:48:03 pm »
you can always use Repository.SQLQuery to get details from the database that are not exposed in the API.
utilisateurEA
« Reply #14 on: March 27, 2010, 02:10:49 am »
How do you have details of what is contained in a connector for example ?
I don't really understand how a SQLQuery(string SQL) works :
do you have to write a SQL request in in the string or the name of the connector ?
(every time I try to use it I have "the SELECT statement includes a reserved word or an argument name is mispelled or missing")
Thank you !
