Author Topic: Enterprise-wide Model Searches  (Read 4709 times)
« on: January 30, 2010, 01:37:02 am »
EA stores repository searches (Model Search Window [Ctrl+Alt+A]) locally to each user (in their local path).  However, many organizations need the ability to create and manage Enterprise-wide searches.  Before I submit a feature request, can anyone suggest any existing mechanism, other than each user manually importing the searches from a central location, on request?
TIA,
Re: Enterprise-wide Model Searches
« Reply #1 on: February 01, 2010, 08:27:39 am »
You can add searches to MDG technologies.
« Reply #2 on: February 01, 2010, 09:46:28 am »
Thanks Simon!
As I read the Help (now I know what I'm looking for), it's a manual tweak of the MTS fil yes?
« Reply #3 on: February 01, 2010, 02:59:46 pm »
Correct, as far as I know it is the only thing that is still required for.
« Last Edit: February 01, 2010, 03:00:38 pm by simonm »
mrf
« Reply #4 on: February 01, 2010, 04:34:17 pm »
You can also perform automation interface based searches via scripts. See the provided scripts for some examples:
* VBScript - Model Search (Attributes) Example
* VBScript - Model Search (Operations) Example
* JScript- Model Search (Attributes) Example
* JScript- Model Search (Operations) Example
EDIT: Script templates may make an appearance in the next build of EA  :-X
« Last Edit: February 01, 2010, 04:37:49 pm by mfraser »
Best Regards,
Michael
