Author Topic: Display of Class Instances  (Read 9897 times)
ChrisBD
« on: May 13, 2010, 05:03:18 pm »
When you add a class instance to class diagram, by default none of the attributes or operations are visible on the diagram.
You can manually set these to be visible, if you select the instance and change its Feature Visibility settings.
I can not see a way to set this so that it is applied to all class instances.
It would be good if there was a global setting so that you could set all class instances to display public operations and attributes automatically, without having to set it individually each time.
Re: Display of Class Instances
« Reply #1 on: May 13, 2010, 06:45:39 pm »
Please submit a Feature Request and tell us the name,
leaving a note here to say you've done it.
We users can then vote for it using a Feature Request with the same name[/color]
ChrisBD
« Reply #2 on: May 13, 2010, 07:15:05 pm »
Done.
Titled:
"Default settings for display of class instances."
Paul Lotz
« Reply #3 on: May 14, 2010, 03:23:19 am »
You can create a template that has the options you want and then use that template in each project.  I tried this a while back and some but not all of the options in the template actually applied.  I haven't tried this for v8.0.
« Reply #4 on: May 14, 2010, 10:17:45 am »
Done.
Titled:
Supported...
SomersetGraham
« Reply #5 on: May 14, 2010, 05:12:38 pm »
+1
Using V12
