Author Topic: Ctrl-X, Ctrl-V to MOVE element between packages ..  (Read 5099 times)
B3ip
« on: January 27, 2011, 12:24:09 am »
Problem:
-often initially create elements in current diagram (therefore package) for convenience)
-can only move thru project browser
-laborious with lots of packages
Idea:
- Ctlr-X to CUT element from current diagram / package
- Ctrl-Shift-X to CUT element from current package
- Ctrl-V to paste into
--- selected diagram
--- selected element
- Support multiple element selection and movement in one move
Benefits
- simpler moves
- vastly speed up inevitable refactoring of project organization
Re: Ctrl-X, Ctrl-V to MOVE element between package
« Reply #1 on: January 31, 2011, 06:58:09 am »
An interesting starting point.
I like the idea of being able to select one or more elements from the project browser or a diagram and moving them elsewhere.
A cut implies a delete.
Because this is a model a delete breaks connections and relationships.
So the implementation would have to take this in to account.
I'm note use you need two keyboard shortcuts depending on contect, surely one would do.
B3ip
« Reply #2 on: January 31, 2011, 05:08:27 pm »
CUT (delete) from the diagram ... not the model ...
interestingly, you already have to Ctrl-Delete to delete from the model ...
« Reply #3 on: February 01, 2011, 12:05:59 pm »
It's ALL in the naming... see: Naming - Remove vs Delete vs Purge
