Author Topic: EA Start as it was left  (Read 7515 times)
RainerQ
« on: June 29, 2011, 04:12:15 pm »
it would be great, if EA would memorize its status
(open windows ect.) when closed, so that I can start next day where I stoped the day before.
Regards
Rainer
Aaron B
Re: EA Start as it was left
« Reply #1 on: June 29, 2011, 04:28:16 pm »
I haven't played with it much, but I think the Working Sets tab in the new Personal Information window in EA 9 allows you to configure this...
- View | Personal Information
- Select "Working Sets" tab
- Right-click in the window and select "Store Main Tab View History"
- Close and reload your model
- Open the "Working Sets" tab again and you should now see an item like "Windows open when Model was last closed".  Right-click on this item and select "Apply when model opens".
Hope that helps.
RainerQ
« Reply #2 on: June 29, 2011, 05:44:55 pm »
Hello Aaron,
thanks for this hint. It does 95% of what I was looking for.
The 5% missing is, that I would like a model to be opend like I left it automatically ;-)
Regards
Rainer
Sunshine
  • Its the results that count
« Reply #3 on: June 30, 2011, 08:41:52 am »
To add 1% more try using menu Diagram>make user default just before you close down EA. That way next time you open up EA it will open up the diagram you were last editing.
Hope that helps a little :)
Happy to help
RoyC
  • Read The Help!
« Reply #4 on: June 30, 2011, 10:10:04 am »
Sunshine's suggestion will open a single diagram automatically when you re-open the project.
You can make a working set open automatically when you open the project, by right-clicking on the set name and selecting the Apply when model opens context menu option.
Very similar to the working set, you can also use a shortcut to open a work-in-progress automatically when you open the project. You set this up using the File | Save Project Shortcut menu option. This enables you to automatically open a number of diagrams, a Model Search, a Relationship Matrix profile and/or the Team Review. You open up the same set of diagrams and profiles each time you open the project, until you edit the shortcut.
These - and more - are all documented in the Help.
« Last Edit: June 30, 2011, 10:11:17 am by RoyC »
Best Regards, Roy
RainerQ
« Reply #5 on: June 30, 2011, 04:54:18 pm »
Hello Roy,
thank you very much for your hint! It gave me the last 5% :-)
@Sunshin:
Thanks for your reply as well. This is what I did, before I learnd about the WorkingSets ;-)
Regards
Rainer
« Last Edit: June 30, 2011, 04:55:17 pm by RQ »
