Author Topic: where is main?  (Read 7635 times)
kalpesh
where is main?
« on: April 12, 2010, 04:27:03 pm »
1. Where is main provided by enterprise architect while code generation?
2. Can anyone tell me how to create object of predefined class?
Makulik
Re: where is main?
« Reply #1 on: April 13, 2010, 02:03:11 am »
Whereever you put it (global namespace of course), if you need to do so. what language are u using? I guess C, C++
or C# ...
I don't understand this question. what's a predefined class? did you mean how to create a classes' instance on a behavioral diagram?? simply drag the class from project tree view to the diagram and choose 'create instance' instead of 'simple link'.
g.
beginner
Re: where is main?
« Reply #2 on: April 13, 2010, 04:24:50 am »
1. Why can't you write question one can understand?
2. Why not read the manual and point out the part you did not understand?
b.
mrf
Re: where is main?
« Reply #3 on: April 13, 2010, 09:20:03 am »
@Beginner,
How is that helpful? You may ask for clarification by all means, but let's try to be a little less condescending. This is a user forum, not the "room for abuse".
@kalpesh
To answer part of your question: EA only generates methods that you have specified in your object model. If you want a main method, then you will need to explicitly add one to a class, or modify a code generation template to add one if a class has a particular stereotype.
For instances of classes (objects) on diagrams see Makulik's post. If you want to prototype an instance of a particular class you can use the Object Workbench (see http://www.sparxsystems.com/uml_tool_guide/visual_execution_analyzer/the_workbench.html)
Best Regards,
Michael
Re: where is main?
« Reply #4 on: April 13, 2010, 04:36:38 pm »
Since this question has been posted in the Automation Interface, Add-Ins and Tools section I assume you want to know how to create an object (instance) of a class through the API?
To do so you need to
- select the location you want the object to be stored (e.g. a package)
- Add a new element to Elements collection of that location (package.Elements.AddNew()) with type = "Object"
- Set the ClassifierID of the new element to the ElementID of the existing class
- Update the new element.
beginner
Re: where is main?
« Reply #5 on: April 13, 2010, 08:44:32 pm »
@Beginner,
Which shouldn't hinder those writing a question to be a bit more elaborate. There are so many threads discussing about what the poster could have meant with his question. Sometimes these discussions are funny and/or fruitful. Sometimes they aren't. Look at this question #2. Where, which under what circumstances for what reason? Adding one or two more sentences to formulate a more clear question would help the poster and those answering.
b.
Makulik
Re: where is main?
« Reply #6 on: April 13, 2010, 10:51:25 pm »
I would be interested in a note from  kalpesh about all that. If we guessed the right things about his questions, what he understood from our answers, a.s.o.
I agree with michael that, if nothing helpful could be said, we should avoid writing anything (that principle was already mentioned recently elswhere by geert if I remember correctly).
I my younger years I've been trying to help moderating the german ISO C++ usenet group. about 70% of questions asked there had nothing to do with ISO C++ or STL, but where OS specific (mostly by the windows developers). There was a FAQ covering these topics (what exactly is discussed in the forum), and where to find information about the topics frequently asked but not covered or wanted there.
There was a standard reply and also the thread title was marked appropriately, when the topic wasn't relevant.
just my 0.02 EUR
g.
« Last Edit: April 13, 2010, 10:52:37 pm by Makulik »
