Author Topic: Othogonal Default Line Style  (Read 5136 times)
philchudley
« on: March 26, 2012, 10:11:07 pm »
Hi All
Anyone else out there just HATE the way that connectors default to Orthogonal Rounded in some MDGS? BPMN 2.0 and Archimate 2.0 spring to mind  >:(
These connectors are extremely frustrating and seem to have a mind of their own. I spend a lot of time making the connector appear as I want, save the diagram, then only to find that when I move some elements the connectors are all messed up again!  >:(  >:(
[highlight]PLEASE, PLEASE in the next release revert the line style default to Custom so we can have control.[/highlight]
Yes I can change the line style after adding the connector, but until such time as to when we can select multiple connectors and change the line style on a selection, the choice of Orthogonal as the default is causing much unnecessary work.
Here's hoping
Cheers
Phil
Models are great!
Re: Othogonal Default Line Style
« Reply #1 on: March 26, 2012, 11:51:15 pm »
Phil,
If the options default style doesn't have any influence, have you tried to add such a link (with the correct line style) in the template package.
That might just help, you never know.
philchudley
« Reply #2 on: March 27, 2012, 12:01:03 am »
Thanks Geert, just tried that, but alas it doesn't work.
It appears that Template Packages only save the first tab settings of the diagram properties, rather than all the settings on all the tabs.
I wanted to create a template of a UML class diagram with the namespace, and visibility indicators turned off. It works for the namespace, but not for the visibility indicators. But we are veering off topic here
Cheers
Phil
Models are great!
philchudley
« Reply #3 on: March 27, 2012, 12:04:06 am »
Follow up to last post, the diagram settings issue mentioned seems to be fixed in version 9.3  :)
Models are great!
