Author Topic: Add Use Case Notes into Structured Scenario  (Read 8095 times)
varium
« on: June 26, 2012, 05:33:49 am »
Please clarify is it possible to add use case elemets' notes into Structured Scenario (Scenario generation based on activity diagram)?
gavind
Re: Add Use Case Notes into Structured Scenario
« Reply #1 on: July 12, 2012, 09:35:48 am »
+1. I'm looking for the same answer.
Two for the Money
SomersetGraham
« Reply #2 on: July 12, 2012, 05:32:36 pm »
Hi
Not sure if this is what you mean
You can enter text into the Description tab of the scenario editor and have EA generate a structured scenario from the entered text
hth
Using V12
varium
« Reply #3 on: July 12, 2012, 11:30:04 pm »
Hi
hth
Hi. I mean following:
1. Create Activity Diagram for Use Case
2. Add some elements to Activity diagram(specify Name and Notes)
3. Generate Structured Scenario from Activity Diagram
4. I would like to see in Scenario as step description Element Name+ Element Notes.
Currently I can see Element Name only.
SomersetGraham
« Reply #4 on: July 12, 2012, 11:47:43 pm »
As far a I know you cannot do this out of the box
You could write an addin to do it
Using V12
