Author Topic: XSD Datatypes  (Read 10168 times)
Alika87
XSD Datatypes
« on: June 26, 2013, 08:26:24 pm »
Hi guys,
I am just working on a project with Enterprise Architect. Now I want to generate a XML Schema of my Model. The only problem here is, that the generator gives me a failure message that looks like this.
Adding class attributes...
      Warning no XSD type found for: "xyz".  Default is: xs:string
and so on, for every selfdefined Datatypes.
My Question now is, where can I define this additional XSD datatypes. I searched and searched but couldnt find any option, to do that.
Thank you very much and best regards.
AndyJ
  • It's only a model
Re: XSD Datatypes
« Reply #1 on: June 27, 2013, 09:05:43 am »
Just a shot in the dark...
Have you defined "types" for your attributes?
Andy
Alika87
Re: XSD Datatypes
« Reply #2 on: June 27, 2013, 05:52:12 pm »
Thank you for your reply Mark.
I defined a couple of own Datatypes. These are the ones, which are not recognized. At the End I get a File, with the package names, Element names, Attribute names but no values for the Attributes.
AndyJ
  • It's only a model
Re: XSD Datatypes
« Reply #3 on: July 03, 2013, 02:36:31 pm »
I'm not sure if you're seeing more than one error.
I just tried adding a fake "type" stuff to an attribute, and received the error you described.
By changing the name of the type to "xs:stuff" it quite happily was imported into the Schema.
Andy
