Author Topic: Document fragments  (Read 4968 times)
Document fragments
« on: January 18, 2016, 10:33:11 am »
I thought it was high time I got to grips with document fragments.
I created a fragment
I then took
and updated it to
and voila, no more images!
Any ideas?
Re: Document fragments
« Reply #1 on: January 18, 2016, 02:28:44 pm »
I think you have to make a distinction between the Package Diagram and the Element Diagram.
So you could need two template fragments.
« Reply #2 on: January 19, 2016, 08:26:22 am »
My memory says that fragments are only applied to elements. Although it is a bit foggy on the issue.
« Reply #3 on: January 19, 2016, 11:09:56 am »
I'm confused about "only applying to elements".
When creating the "fragment" the EA document editor seemed to provide me with the full power of the "Sections".
Does that mean I should manually delete the package > <package tags/brackets?
Or I cannot have a fragment with a diagram > <diagram tags?
Its odd that under "Sections" diagram appears twice, directly under package, and again under package > element; and further that one has no subsections, the other does have subsections.
In any case I would have expected that the diagrams under elements should have shown up
