Author Topic: Changing default diagram properties  (Read 12226 times)
gpatenaude
    • LinkedIn profile
« on: March 17, 2016, 11:47:35 pm »
Is there a simple way to change default diagram properties? (not by building a whole new MDG technologies to override every single diagram types...)
I'd like to have the "Disabled fully scoped object names" checked by default when people are creating new diagram in our shared repository.
Thanks!
If anyone tries to tell you that your estimate is bogus because the task is so simple, ask them to write down the procedure for tying their shoes.
PeterHeintz
Re: Changing default diagram properties
« Reply #1 on: March 17, 2016, 11:50:50 pm »
TOOLS/Options.../Diagram
Best regards,
Peter Heintz
Richard Burke
    • Protean Electric
« Reply #2 on: March 18, 2016, 03:18:29 am »
Also by using templates if you want to do it on a diagram by diagram basis. Create a Templates package and put a diagram of the required type in there, setting whatever options you want. Then set the project's template package using:
Project , Settings, Project Template Package ...
Richard Burke
Software and Systems Manager
Protean Electric Limited
steveycnash72
« Reply #3 on: April 16, 2016, 06:35:27 am »
Hi Richard,
Thanks for the tip. To the best of your knowledge, is this the only way to set the default "Use Alias If Available" on newly created diagrams?
Richard Burke
    • Protean Electric
« Reply #4 on: May 12, 2016, 06:01:34 pm »
Sorry Steve, not an expert on this.
Richard Burke
« Reply #5 on: May 12, 2016, 06:22:38 pm »
I think you can only do it this way, or with an add-in. (maybe also with in a stereotyped diagram in a UML profile, but I'm not sure of that)
