Author Topic: Image manager improvement  (Read 8638 times)
Guillaume
    • www.umlchannel.com
« on: March 31, 2016, 11:13:53 pm »
One of our client is struggling with the management of images within their EA projects.
Even when images have been renamed, it is difficult to manage them when you have over 100/200.
It would be useful to improve the Image Manager e.g. with the following:
- add types or categories to group images (e.g. similar to the glossary)
- add a search on image names
- have the ability to generate an XML Reference Data file with a selection of images (not all)
- when copying a package from an EA project to another one, it would be good to select the image we want to keep in the target EA project (or merge with an existing image in the target project)
Guillaume
jfzouain
Re: Image manager improvement
« Reply #1 on: April 01, 2016, 12:22:38 am »
I second all too.
Best regards
Jose Zouain
« Reply #2 on: April 06, 2016, 02:13:43 pm »
+1
Glassboy
« Reply #3 on: April 06, 2016, 02:55:32 pm »
preach brother
Uffe
« Reply #4 on: April 06, 2016, 10:54:43 pm »
+1
Adding categorization would likely require a change to the DB schema, so that probably won't happen, but a treeview based on the first letter could be useful.
Also, a better naming scheme for auto-created images (created when you Apply Image from Clipboard) would help.
Instead of "Image9999", how about "Img <diagram name> <yymmdd>"? (Bearing in mind that elements may be nameless, but diagrams may not.) Or failing that, just "Img <yymmdd>-999"?
I'd also like to add that the Usage function is very useful, but the result dialog should be labelled "Image Usage", not "Element Usage".
Also, the image ID shown in the result dialog is never seen anywhere else in the GUI -- you have to do a DB search to find it. So that column can go, or at least it can be hidden.
/Uffe
Graham_Moir
« Reply #5 on: April 19, 2016, 09:58:52 pm »
+1
« Reply #6 on: April 20, 2016, 06:34:35 am »
Living in hope
On a related note it is a shame that the inability to make schema improvements appears to be gradually increasing technical and business functionality debt
pps <yyyymmdd> please
Glassboy
« Reply #7 on: April 20, 2016, 06:58:27 am »
hope
hope you don't get flooded out?  hope you can find a decent cup of coffee?
