Author Topic: Drag and drop as "link" creates a new blank diagram  (Read 8305 times)
Phillimo
« on: April 19, 2016, 02:34:38 am »
Scenario:
Drag and drop Business Process A (From Package A) as a link on Diagram B (Package B) and a new blank diagram appears under Package A.
The linked element does not link to the original one we dropped, instead it links to the newly created empty diagram.
Is this a bug? We have been dropping business process diagrams as links for a while and never encountered this issue. We need to reference the same business process diagram in many scenarios, so it would be a shame if the feature did not work.
Thanks, Sam.
« Last Edit: April 19, 2016, 02:40:36 am by Phillimo »
Re: Drag and drop as "link" creates a new blank diagram
« Reply #1 on: April 19, 2016, 03:32:40 am »
Sam,
Are you dropping  the diagram or the Business Process as a link?
If Business Process, which kind? BPMN1.0, BPMN2.0, EA's own business processes?
Do you actually see the dialog giving you the options to drop as link/instance?
Zvolensky
  • Do... or do not. There is no try.
« Reply #2 on: April 19, 2016, 01:41:52 pm »
Hello
I work with Phillimo...
The business process type is BPMN2.0.
Dropping it as a link on an empty Business Process type diagram
When dropping, the dialog appears and we are using the Drop as Link option
This is happening not only on a shared repository (MSSQL) but also on a local file.\
I'm using EA 12.1 build 1229, Phillimo 1228 i think.
Thx.
Maros
« Reply #3 on: April 19, 2016, 02:06:53 pm »
No, I've never seen this type of behavior. Dropping something as link should never create a new diagram I think.
Does this happen on all business processes, or just on some?
There are a couple of things you can try:
- Reset BPMN prompts (a button somewhere in the options)
- Run a Project Integrity Check (Shift-F9) and fix all errors
Zvolensky
« Reply #4 on: April 19, 2016, 02:14:48 pm »
Hello
Yes, it's strange
here is the video
https://youtu.be/0U6AvrQ5684
Zvolensky
« Reply #5 on: April 19, 2016, 02:51:13 pm »
Hello
reset prompts and integrity check (no issues found) did not helped. :-(
any other idea?
VKN
« Reply #6 on: April 19, 2016, 03:07:36 pm »
I can reproduce it.
You may want to submit a bug report.
« Reply #7 on: April 19, 2016, 09:57:06 pm »
Try turning off all MDG's and add-ins except for the the standard EA ones and BPMN 2.0
Zvolensky
« Reply #8 on: April 20, 2016, 01:52:28 pm »
Hello
No joy, turned off all extensions and all add ins, restarted Sparx, only BPMN2 was what was left and it did not helped. :(
