Author Topic: Where did the rest of the notes go?  (Read 4719 times)
SomersetGraham
« on: June 30, 2010, 08:50:26 pm »
Hi all
If you have a note element with a single line of text then this text is stored in the Note column of t_object.
If you have a multiline note element then the first line only appears in t_object.
Anyone know what table the remaining text is stored in
TIA
Graham
Using V12
Re: Where did the rest of the notes go?
« Reply #1 on: June 30, 2010, 08:58:22 pm »
Graham,
I think you can only see the first line, but that the column in fact holds the whole note (including line breaks)
SomersetGraham
« Reply #2 on: June 30, 2010, 09:00:27 pm »
Thanks Geert
I'll look into it
Graham
Using V12
« Reply #3 on: July 01, 2010, 12:45:49 am »
Graham,
Hi Graham,
Geert is absolutely correct.  The Notes columns are MS-Access Memo columns.  If you make the row height greater than 1 line you'll see the rest of the Note.  You can also, after a fashion, scroll within the cell...
SomersetGraham
« Reply #4 on: July 01, 2010, 12:58:01 am »
Thanks to all
Using V12
