Author Topic: EA13 Sweeper and 'HV Lock'  (Read 14996 times)
Ian Mitchell
« on: June 13, 2016, 10:15:47 pm »
A few new menu options have appeared in V13, which don't seem to have any help - odd, as they are in the 'Helpers' bit of the 'Layout' ribbon.
  • What does 'sweeper' do (and please don't say 'sweep'
  • And 'HV Lock'
www.eaDocX.com
www.theartfulmodeller.com
Re: EA13 Sweeper and 'HV Lock'
« Reply #1 on: June 13, 2016, 10:59:12 pm »
When you turn on Sweeper you will no longer drag a frame for multi-selection but sweep element around. Well, ...
HV Lock locks elements to be moved only Hor./Ver. when being dragged. Well,...
« Reply #2 on: June 14, 2016, 09:12:16 am »
Did you try the help?
http://sparxsystems.com/enterprise_architect_user_guide/13.0/the_user_interface/using_the_helpers_panel.html
PS. I used the above search in EA User Guide for sweeper.
« Last Edit: June 14, 2016, 09:14:19 am by Simon M »
RoyC
  • Read The Help!
« Reply #3 on: June 14, 2016, 09:13:32 am »
There is a large section on Ribbons in the Help, in the User Interface chapter. You should be able to find a description of every option you see in the Ribbons.
And Simon has been even more specific!
Best Regards, Roy
Ian Mitchell
« Reply #4 on: June 14, 2016, 11:07:50 pm »
...so try putting 'sweeper' into the 'search' in the help.
If I search for something in the help, and I get no search results, then I assume there is no help for that thing. Is this not true?.
Perhaps you might add some additional text into the help:
"Your search didn't produce any results. But that doesn't mean it's not there, so keep looking anyway."
"Or it might mean there really isn't any help about what you wanted. We're not telling...."
www.eaDocX.com
RoyC
  • Read The Help!
« Reply #5 on: June 16, 2016, 09:23:39 am »
What exactly did you do?  If I go to the 'Start > Help > Help Icon > Search Help' option, and type 'Sweeper' into the text field, I get three references to the 'Using the Helpers Panel' Help topic.
There isn't a 'search list' to add the 'Sweepers' text string to. The Search facility searches the actual text of the Help, not an index, so if there is a mention of the subject in the Help the search should find it.
Best Regards, Roy
« Reply #6 on: June 16, 2016, 09:59:57 am »
Don't forget, Ian, that now you have to make sure that the search case is correct...  Been caught out a number of times.
Wrong casing may not find stuff that IS there...
« Reply #7 on: July 24, 2016, 07:26:15 pm »
I thought I'd try it out - both "sweeper" and "Sweeper" elicited
Up, thats right, a big fat nothing.
On the other hand, if you search sparx systems (and you alsmost cant avoid doing this as the search will not stay set on EA User guide)
you do get (and no its not case sensitive)
lol
« Reply #8 on: July 24, 2016, 07:27:03 pm »
Yup, thats right, a big fat nothing.
On the other hand, if you search sparx systems (and you alost cant avoid doing this as the search will not stay set on EA User guide)
lol
RoyC
  • Read The Help!
« Reply #9 on: July 25, 2016, 10:03:07 am »
And if you try using the Help Search facility within the Help System, as I suggested earlier?
Best Regards, Roy
« Reply #10 on: July 25, 2016, 12:13:54 pm »
Is there a difference between the EA USer Guide and "within the system"?
RoyC
  • Read The Help!
« Reply #11 on: July 25, 2016, 04:03:00 pm »
Sorry, I think I got my EA and my Help mixed up.
What I meant was, within EA click on the Start Ribbon, Help panel, Help icon and select the Search Help option. Type in your search string. That search ought to find any occurrence of the text string in the entire Help system. I don't believe that is the same search mechanism as is behind the website search at the (very) top of the Sparx website page.
Best Regards, Roy
« Reply #12 on: July 25, 2016, 04:55:44 pm »
As I see it this just feeds the browser's search field. You're just talking about loosing your head.
« Reply #13 on: July 26, 2016, 08:27:45 am »
Searching 'EA User Guide' from the website searches help for the current official release. Currently 12.1.
Searching the web help from EA or any 13.0 help page searches the help for 13.0.
Searching 'Sparx Systems' from the website currently searches both versions of the help as well as everything else.
« Reply #14 on: July 26, 2016, 09:11:59 am »
Thanks Simon M
