Author Topic: SetAppearance removes element type  (Read 18160 times)
royvanmarrewijk
« on: July 04, 2016, 09:14:42 pm »
I am writing a script (JScript) which set the global color of the blocks and there instances. I use the SetAppearance function to do this but when I color an instance the element type of the instance within an internal block diagram disappears. So can anyone tell me how to prevent this or how I can enable 'show element type' with scripting?
kind regards,
Roy van Marrewijk
Re: SetAppearance removes element type
« Reply #1 on: July 04, 2016, 09:25:37 pm »
I'm not sure about the coloring question. There is per element and per diagram coloring. The latter overrides the first.
Regarding Type: diagram.StyleEx contains VisibleAttributeDetail which can be set to 0 (name and type; see p. 73 of my Inside book).
royvanmarrewijk
« Reply #2 on: July 04, 2016, 09:52:16 pm »
Hi qwerty,
Thanks for your quick reaction!!
Normally we right click on an element in the internal block diagram and then select advanced -> Show element type, this of course wil show the type of the selected element. I would like to automate this and I am going to try out your idea.
Roy
royvanmarrewijk
« Reply #3 on: July 04, 2016, 10:53:59 pm »
I tried to edit the diagram styleEX but that didn't work out. This is what my code look likes:
diagram.StyleEx = "ShowAsList=0;"+
"AdvanceElementProps=1;"+
"ShowTests=1;"+
"ShowMaint=1;"+
"ShowNotes=1;"+
"HideQuals=0;"+
"AdvancedFeatureProps=1;"+
"ShowOpRetType=1;"+
"SuppressBrackets=1;"+
"AttPkg=1;"+
"VisibleAttributeDetail=1;"+
"TExplicitNavigability=1;"+
"AdvancedConnectorProps=1;"+
"SuppConnectorLabels=1;"
diagram.Update();
With this code I see some changes but not the required element type.
Can anyone provide me with some tips & tricks?
Roy
« Reply #4 on: July 04, 2016, 11:03:58 pm »
Roy,
You'll have to figure out what exactly EA changes in order to make the element type appear.
I'm guessing it will be something on the DiagramObject rather the Diagram.
A useful tool in such circumstances is a profile (such as the one in SQL Server) so you can record every query EA executes on the database and thus easily spot the place where EA hides this information.
« Reply #5 on: July 05, 2016, 07:11:11 am »
Unfortunately you are likely referring to SysML which I don't have. So you are probably bound to what Geert suggests. What I do is to export the contents of all tables before and after an update and then run Winmerge on the dump. This way I just need EAP files and have no need for a more complex RDBMS.
royvanmarrewijk
« Reply #6 on: July 05, 2016, 04:21:57 pm »
Since I don't want to ruin the general model I am scripting in a local .eap. So is there an option to read / export the database behind the .eap so I can compare it.
kind regards,
Roy
PeterHeintz
« Reply #7 on: July 05, 2016, 04:56:14 pm »
Not sure what you have in mid for compare. .eap is a MS-Access DB (just to long ago that I worked with Access to know I comparing two DB’s is simple or not.
Another option would be transferring it to a real SQL DB like oracle, MySQL, MS-SQL,…
Best regards,
Peter Heintz
« Reply #8 on: July 05, 2016, 06:40:43 pm »
I use a litte Perl script for the export (I use a few Mickeysoftware as possible). If you have M$ Access you can open the EAP (eventually you need to rename it to .mdb IIRC). I don't know what it offers on extra tools. I know you can use VB inside too, but that would not be much different to using it from inside EA.
royvanmarrewijk
« Reply #9 on: July 05, 2016, 07:48:26 pm »
Thanks again!
I've installed a MySQL database on my pc and exported my project to this database. After I compared the two exports (before and after the change) I discoverred that t_diagramobject.ObjectStyle contains the information (PType = 1) as you allready expected. Only when the property type must be shown the PType string will be visible in the ObjectStyle field.
Thanks for giving me directions!
Roy
royvanmarrewijk
« Reply #10 on: July 05, 2016, 07:57:21 pm »
FYI:
I used the following code to set the colors of a diagramObject to 'default'
diaObj.Style = "BCol=-1;BFol=-1;LCol=-1;LWth=-1;";
diaObj.Update();
because the function "element.SetAppearance(0, 0, white)" didn't do the trick.
So this is the cause of the failure.
Roy
« Reply #11 on: July 05, 2016, 10:01:36 pm »
Element.SetAppearance influences the element's general appearance. If you place it on a fresh diagram it will have the specified color. But you can override this color locally per diagram (this is what your code piece is doing).
« Reply #12 on: July 06, 2016, 02:04:32 am »
FYI:
diaObj.Update();
Roy
Cool. Thanks for posting the solution as well.
« Reply #13 on: July 06, 2016, 08:38:59 am »
diaObj.Update();
Roy
That code replaces everything in the style string with exactly the string that you have specified. So, yes it will remove any other settings associated with that diagram object.
