Author Topic: Updating glossary results in warning that glossary with same name alread exists  (Read 4983 times)
mrblack12
HI,
i'm trying to update a few glossary items but I keep getting the blocking message that "A glossary with the same name already exists". Anybody knows how to prevent this from happening?
Thanx,
Rick
It looks like you rather try to add than to update. What are you doing exactly?
VKN
That error may appear if you're trying to change just the case of the existing glossary term.
Glossary terms are not case sensitive.
If you'd like to achieve that anyway then rename it to a different temporary name then again rename it to the original name with the desired case.
« Last Edit: July 12, 2016, 09:54:58 am by VKN »
mrblack12
Thanks for your replies! It was the latter:I did try to change the case of an existing glossary item....
I stumbled over this once (a nice example of EAUI). That time I created my own glossary from MDG-defined elements.
