Author Topic: VBscript: Adding multiplicity  (Read 7680 times)
Scorpion2k
« on: August 08, 2016, 06:13:49 am »
Hello everyone,
This is my first post on this forum. I'm using Enterprise Architect for a little while now and I'm focussing on generating a datamodel from Excel.
At first I tried using "eaexcelimporter_v4.xls" but it did not work for me. The company I work at has some strict network policies and makes importing from Excel to EA impossible. So I started a VBscript in EA and now it reads the Excel.
So far I learned how to create an element with properties, attributes with properties, tagged values and creating connections. Now I have one challenged left, multiplicities.
I have really learned a lot from the local scripts and the excel from Geert Bellekens. But I can't find anything on the internet about adding multiplicities.
It reads the information from an Excel with the following layout:
ABCDEFGH
1Source_NameSource_IDTarget_NameTarget_IDTagged_ValueSource_MultiplicityTarget_Multiplicity
2Chair12975Desk12945P110..*
3Computer12954Desk12945P21..*0..*
It creates an connection with the Source_ID and Target_ID. It also adds a TaggedValue. I want it to add the multiplicity too, but I can't figure out the proper code to do this. I tried many ways, but my work comes to a stand still. I added my code with this post. It's no clean code and has no error handling, but that comes later, after I get used again to VBscript.
I hope someone can help me to add the multiplicity in VBscript.
sub Relations
Repository.EnsureOutputVisible "Script"
dim Package as EA.Package
set Package = Repository.GetTreeSelectedPackage()
if not Package is nothing and Package.ParentID <> 0 then
dim objExcel
dim objWorkbook
dim objWorksheet
dim path
dim file
path = "D:\Modellen\Importbestanden\"
file = "Relationship_Matrix_Input.xlsx"
set objExcel = CreateObject("Excel.Application")
set objWorkbook = objExcel.Workbooks.Open(path & file)
set objWorksheet = objWorkbook.Worksheets("Relations")
dim Object_sourceID as EA.Element
dim Object_targetID as EA.Element
dim Object_source as EA.Element
dim AddRelation as EA.Connector
dim Line
dim Check
Check = ""
Line = 2
Session.Output( "Relations from Excel" )
Session.Output( "====================================" )
dim tags as EA.Collection
dim newTag as EA.AttributeTag
Do Until objWorksheet.Cells(Line,1).Value = ""
If Check <> objWorksheet.Cells(Line, 1).Value Then
Object_sourceID = objWorksheet.Cells(Line, 3).Value
Object_targetID = objWorksheet.Cells(Line, 5).Value
set Object_source = Repository.GetElementByID(Object_sourceID)
set AddRelation = Object_source.Connectors.AddNew("", "Association")
AddRelation.SupplierID = Object_targetID
AddRelation.Update
' TAGS aan en uit zetten
set tags = AddRelation.TaggedValues
set newTag = tags.AddNew( "Tag Matrix", objWorksheet.Cells(Line, 6).Value )
newTag.Update()
tags.Refresh()
Check = objWorksheet.Cells(Line, 1).Value
Session.Output( objWorksheet.Cells(Line, 2).Value & " AddRelation met " & objWorksheet.Cells(Line, 4).Value & " with priority " & objWorksheet.Cells(Line, 6).Value & ".")
set Object_sourceID = nothing
set Object_targetID = nothing
set Object_source = nothing
set AddRelation = nothing
set tags = nothing
set newTag = nothing
End If
Line = Line + 1
Loop
Session.Output( "AddRelations verwerkt" )
objExcel.Quit
else
MsgBox( "No package found" & vbCrLf & _
"Select a package and try again." )
end if
end sub
Relations
« Last Edit: August 08, 2016, 06:15:46 am by Scorpion2k »
Dermot
Re: VBscript: Adding multiplicity
« Reply #1 on: August 08, 2016, 04:01:25 pm »
« Reply #2 on: August 08, 2016, 04:35:37 pm »
See AssociationEnd.cs
and Multiplicity.cs for a C# example on handling multiplicity.
Scorpion2k
« Reply #3 on: August 08, 2016, 06:56:04 pm »
Thank you for the advice. I think I can learn a lot from the links. I will try this out this week. Thank you!
Scorpion2k
« Reply #4 on: August 18, 2016, 01:19:14 am »
The links and examples made me understand the logics of EA a lot better. I solved my problem and enabled me to write more enhanced scripts. In case someone else has the same problem, here's my solution. The solution to my problem was fairly easy. I just needed to add the following lines before the AddRelation.Update
AddRelation.ClientEnd.Cardinality = objWorksheet.Cells(Line, 7).Value
AddRelation.SupplierEnd.Cardinality = objWorksheet.Cells(Line, 8).Value
Thanks again!
