Author Topic: Spreadsheet tool that could import tagged values  (Read 3283 times)
Nigel Campbell
« on: September 18, 2010, 01:20:11 am »
If I had a spreadsheet with a set of entries that looked like:
Field NameBlurb xxx xxx xxx xxx xxx xxx xxx xxx xxx xxx xxx xxxData type
Tag type 1Tag Value 1
Tag Type 2Tag Value 2
The end result I'd like would be a set of fields on a table in a database model with the tags populated (essentially coverage tracking, requirements linkage and issue/question tracking for an ETL spec).
Does anyone know of a tool, code example or some such that can do a bulk import of attributes on an element, including populating tagged values?
I can program, so something that needed a bit of modification would be OK.  I'm really after a quick start.
Nigel.
Re: Spreadsheet tool that could import tagged valu
« Reply #1 on: September 20, 2010, 03:25:03 pm »
