Author Topic: Determine user  (Read 20676 times)
1c3m4n
Determine user
« on: October 15, 2010, 11:50:24 pm »
i get the currently logged in user by using the command
repository.GetCurrentLoginUser(false);
Is it possible to determine the forename and surname of this user?
Have a nice weekend.
Florian
« Last Edit: October 15, 2010, 11:51:44 pm by 1c3m4n »
Re: Determine user
« Reply #1 on: October 16, 2010, 12:52:48 am »
Florian,
I think the only way is to query the t_secuser table.
You can use Repository.SQLQuery to execute a query to the database.
1c3m4n
Re: Determine user
« Reply #2 on: October 18, 2010, 05:34:08 pm »
Hi Geert,
thank you for your answer. Can you please specify what i need to write in the SQL string parameter of the SQLQuery function.
Thanks.
Florian
Re: Determine user
« Reply #3 on: October 18, 2010, 05:56:20 pm »
Something like
"Select u.FirstName, u.Surname from t_secuser u
where u.UserLogin = '" + loginVariable + "'"
should do the trick.
« Last Edit: October 18, 2010, 05:56:47 pm by Geert.Bellekens »
1c3m4n
Re: Determine user
« Reply #4 on: October 18, 2010, 06:21:05 pm »
It works !
Thank you !
Florian
