Author Topic: Check project authors  (Read 25968 times)
1c3m4n
« on: October 19, 2010, 11:11:59 pm »
i want to check, if the repository user equals in the project authors list. I successfully determined the rep. user, but i had some problems to check the project authors list.
I tried the repository.authors.... functions, but it didn't work.
Can you please give me a good solution?
Thanks.
Florian
1c3m4n
Re: Check project authors
« Reply #1 on: October 20, 2010, 12:23:55 am »
I have solved the problem. Now i want to create a new project author. How can i do this?
« Reply #2 on: October 20, 2010, 04:23:10 pm »
From TFM:
Authors
 Collection
 Read only. The system Authors collection. Contains 0 or more Author objects, each of which can be associated with, for example, elements or diagrams as the item author or owner. Use AddNew, Delete and GetAt to manage Authors.
1c3m4n
« Reply #3 on: October 20, 2010, 06:53:18 pm »
Hi Geert,
thank you, i have already tried this. The AddNew function has 2 arguments:
string name: The name of the new project athor?
string type: What does this mean?
Cheers,
Florian
« Reply #4 on: October 20, 2010, 06:58:20 pm »
I think you'll have to use as such:
myRepository.Authors.AddNew("AuthorName","Author")
1c3m4n
« Reply #5 on: October 20, 2010, 07:17:54 pm »
I have tried this, but it doesn't create a new author.
« Reply #6 on: October 20, 2010, 07:20:01 pm »
Post the code snippet, there might be an update() missing or something like that.
1c3m4n
« Reply #7 on: October 20, 2010, 07:22:57 pm »
Ok, here is the snippet which should create the new author:
// Author nicht vorhanden -> neu anlegen
Log = "Project Author nicht vorhanden";
oberflaeche.vSetMessage(Log);
repository.Authors.AddNew("Project Author", "Author");
repository.Authors.Refresh();
« Reply #8 on: October 20, 2010, 07:27:17 pm »
try
EA.Author newAuthor = repository.Authors.AddNew("Project Author", "Author");
newAuthor.Update();
1c3m4n
« Reply #9 on: October 20, 2010, 07:32:58 pm »
Thank you very much !!!
I got an error message with the use of your solution. I modified your code, now it works.
Here it is:
EA.Author newAuthor = repository.Authors.AddNew("Project Author", "Author") as EA.Author;
newAuthor.Update();
« Reply #10 on: October 20, 2010, 07:35:45 pm »
Oh, yes sure, I forgot the cast to Author.
PS. I hate EA.Collection >:(
1c3m4n
« Reply #11 on: October 20, 2010, 08:08:17 pm »
I agree :)
« Reply #12 on: October 21, 2010, 08:43:01 am »
Well, you could always use the Java interface.  It's slightly easier in that the collections are generics.  Here's a sample from the code samples directory in EA.
Collection<Author> authors = rep.GetAuthors();
String newAuthorName = "Author P. McAuthor";
Author newAuthor = authors.AddNew( newAuthorName, "Writer" );
newAuthor.Update();
authors.Refresh();
« Last Edit: October 21, 2010, 08:45:08 am by simonm »
