Author Topic: unintelligible text in Common-note  (Read 16361 times)
madcherry
« on: August 15, 2016, 04:55:05 pm »
Hi,I can add note for the Activity in Chinese character yesterday.Today i add new note ,all the Chinese character input change to ????.All note already exist seems OK but i can't do any change.Please help me thx.
Re: unintelligible text in Common-note
« Reply #1 on: August 15, 2016, 07:17:07 pm »
You're probably using EAP files with Jet 3. Switch Tools/Options to Jet 4. You also need to download the Jet4 base model from somewhere on Sparx' site.
madcherry
« Reply #2 on: August 15, 2016, 09:35:43 pm »
Thanks for your answer.I stil have the issue
1.I check the OLE DB,I have the microsoft jet 4.0 OLE DB Provider(It's mean my computer have jet4?)
2.I check the tool-option-use jet4.0 and restart my computer,It's not work.
3.My OS is win8
We use the svn to management EA Project,my colleague don't have the issue.their OS WIN7 or WIN10
I also try download the EABase Jet4 from the follow URL,but stil not work in my computer...
http://sparxsystems.com/enterprise_architect_user_guide/12.1/project_management/check_in_languages_other_than_.html
madcherry
« Reply #3 on: August 15, 2016, 09:53:37 pm »
I try copy and paste can work.
Direct input can not work..
« Reply #4 on: August 15, 2016, 11:47:04 pm »
I remember that user skiwi had an issue with some local characters, but that's some time ago. What is your EA version?
Dermot
« Reply #5 on: August 16, 2016, 11:17:46 am »
With the Jet 4.0 you do need to convert the Jet 3.5 .eap to Jet 4.0. For more details on this see the notes on:
http://sparxsystems.com/enterprise_architect_user_guide/12.1/introduction/startea.html
& Download the Jet 4.0 base from:
http://www.sparxsystems.com/bin/EABase_JET4.zip
madcherry
« Reply #6 on: August 16, 2016, 12:35:44 pm »
1. 12.0.1210(Build1210) while the issue happen
2. I uninstall the EA, try a new version 12.0.1214(Build 1214) it's not work
« Reply #7 on: August 16, 2016, 01:34:27 pm »
Have you transferred your project from your JET 3.5 EAP file to a JET 4 EAP file?
madcherry
« Reply #8 on: August 16, 2016, 03:36:24 pm »
Hi KP,
I do as follow
1.Download  Jet 4.0 base from http://www.sparxsystems.com/bin/EABase_JET4.zip
2.Create a new project test2.eap(have the issue)
3.Use file to file transfer,source select test2.eap ,target is EABase_JET4.eap
It's not work.
« Reply #9 on: August 23, 2016, 09:12:58 am »
Creating a new .EAP repository from within EA will create a Jet 3 (non-Unicode version).
Copy and rename the downloaded Jet4 .EAP file and double click to open it.
Glassboy
« Reply #10 on: August 23, 2016, 09:15:29 am »
Nice pixelation but some of us know who you are :-)
« Reply #11 on: August 24, 2016, 10:09:15 am »
I don't think that JET 4 is the issue.
  • Existing notes work
  • Copy and paste works
  • Direct input doesn't
  • This has only been described for notes
I suspect a problem with the IME edit mode for Chinese in the note fields.
What OS are you running?
What keyboard layout are you using?
What codepage (language for non-unicode programs) is set?
« Reply #12 on: August 25, 2016, 02:20:31 pm »
ah, well, in that case, on Windows 7 64bit, using Ea12.1.1224, a SQL server repository, and
English (New Zealand) with Maori keyboard
I confirm that I can (still) not enter, via a keyboard, āēīōū etc into the notes field (but it works find in the name, alias, keywords, author fields for example).
These characters can be pasted into the notes field.
« Reply #13 on: August 25, 2016, 04:58:31 pm »
It's 'coz you keep winning the Bledisloe.  The Sparxians are in OZ...  Work it out...  ;)
Having it work in parts of the UI and not in others is them "turning the knife".
« Reply #14 on: August 26, 2016, 08:45:04 am »
Kiwi, I honestly thought the Maori keyboard was working in the notes editor. We did have it working here.
Unfortunately, it reminds me of a similar situation with an Eastern European language that had similar problems. I remember that after creating a Windows install in that language we still couldn't reproduce it. It ended up being that installs various software changed the codepage definitions in the windows, and that's what was causing the issue.
If you want to send in another bug report on the topic (or re-open an existing one) then we can investigate further. But I'm completely out of ideas.
PS. I've heard of "Bledisloe" paired with cup, so I assume it's a sporting event.
