Author Topic: Create autom. a Class Diagram after a new Package  (Read 52937 times)
Re: Create autom. a Class Diagram after a new Pack
« Reply #15 on: October 21, 2010, 07:10:15 pm »
Index is of type "object", so it can be any type, including string or integers.
I think the idea is to allow us to use both the index as the name of the property.
So it seems to be both Get("PackageID") as Get(0) (or Get(1), i don't know if it is zero- or one-based) should work.
marine1981
« Reply #16 on: October 25, 2010, 10:15:53 pm »
I'm not really progressing. I've got a problem. With ...
diagram1 = package1.Diagrams.AddNew("Logical Diagram", "Logical");
it generates a new diagram. So far so good.
But at first I must set the pointe to the package1 with:
package1 = Repository.GetPackageByID(intPackageID)
How I get the intPackgeID?  I have used Info.Get(object index) but without any success. Because I don't find the right parameter for this method. Do you haven any idea?
Sven
« Reply #17 on: October 25, 2010, 11:17:41 pm »
Sven,
If I find the time later on I'll try it out, but in the meantime you can try to ask Sparx support using the link on the bottom of the page.
They are usually quite responsive, but keep in mind that they live upside-down, and it's the middle of the night for them at the moment.
marine1981
« Reply #18 on: October 26, 2010, 01:11:53 am »
Oh, thanks. That's very nice.
« Reply #19 on: October 27, 2010, 05:18:14 pm »
Sven,
I did a little test, and this code works:
       public void EA_OnPostNewPackage(EA.Repository Repository, EA.EventProperties Info)
            EA.EventProperty packageID = Info.Get("PackageID");
            EA.Package newPackage = Repository.GetPackageByID(int.Parse((string)packageID.Value));
            string test = newPackage.Name;
marine1981
« Reply #20 on: October 29, 2010, 05:12:03 pm »
Your code is very helpful. It generates a new diagram now but in the false level. I need the diagram under the package folder.
« Reply #21 on: October 29, 2010, 05:19:04 pm »
Sven,
Where it it creating the diagram then?
Post the code you have now, I'll have a look.
marine1981
« Reply #22 on: October 29, 2010, 08:56:38 pm »
Hello Geert,
i think, i have got a update/refresh problem.
    public virtual bool EA_OnPostNewPackage(EA.Repository Repository, EA.EventProperties Info)
            EA.EventProperty PackageID = Info.Get("PackageID");
            EA.Package NewPackage = Repository.GetPackageByID(int.Parse((string)PackageID.Value));
            //Zuweisung des Packagenamens auf den Diagramnamen
            //Trim() entfernt überflüssige Leerzeichen am Stringanfang und -ende
            packageName = packageName.Trim();
            EA.Diagram NewDiagram = (EA.Diagram)NewPackage.Diagrams.AddNew(Convert.ToString(packageName), "Logical");
            NewPackage.Update();
            NewDiagram.Update();
            //Zuweisung elementName
            // Werte für Substring(StartWert, Länge) werden berechnet
            // Berechnung der Startposition am String
            startWertStringPosition = packageName.IndexOf('-') + 1;
            // Berechnung der Stringlänge
            zeichenLaengeString = packageName.IndexOf('(') - startWertStringPosition;
            elementName = packageName.Substring(startWertStringPosition, zeichenLaengeString);
            elementName = elementName.Trim();
            EA.Element NewElement = (EA.Element)NewPackage.Elements.AddNew(Convert.ToString(elementName), "UseCase");
            //Zuweisung des elementAlias
            startWertStringPosition = 0;
            zeichenLaengeString = packageName.IndexOf('-');
            elementAlias = packageName.Substring(startWertStringPosition, zeichenLaengeString);
            NewElement.Alias = elementAlias.Trim();
            //Zuweisung elementStereotype
            startWertStringPosition = packageName.IndexOf("(Ebene") + 6;//Startwert
            zeichenLaengeString = packageName.IndexOf(")") - startWertStringPosition;
            elementStereotype = packageName.Substring(startWertStringPosition, zeichenLaengeString);
            NewElement.Stereotype = elementStereotype.Trim();
            NewElement.Update();
            NewPackage.Elements.Refresh();
« Reply #23 on: October 29, 2010, 09:40:51 pm »
Seems OK to me, where is it creating the diagram?
Or do you mean that you don't see the diagram and the new element in the project browser immediately?
In that case Repository.AdviseElementChange (NewPackage.Element.ElementID)  should fix that. (although I had some issues with that operation in the past, if it isn't working as expected try Repository.RefreshModelView (NewPackage.PackageID))
marine1981
« Reply #24 on: October 29, 2010, 09:50:58 pm »
Yes, I don't see the diagram and the new element in the project browser immediately.
I think he need a update like "reload project".
After then I have got the right view.
When and Where it needs a update?
« Last Edit: October 29, 2010, 10:00:33 pm by marine1981 »
« Reply #25 on: October 29, 2010, 09:52:47 pm »
That is "normal". Apparently the GUI doesn't know about updates performed by the API, so you have to tell the GUI to update itself.
marine1981
« Reply #26 on: October 29, 2010, 10:01:20 pm »
« Reply #27 on: October 29, 2010, 10:26:16 pm »
marine1981
« Reply #28 on: November 01, 2010, 04:52:26 pm »
I have fixed that but i does not work with one of the both fixes.
Repository.AdviceElementChange(NewPackage.Element.ElementID);or
Repository.RefreshModelView(NewPackage.PackageID);
« Reply #29 on: November 03, 2010, 05:38:26 pm »
RefreshModelView(0) should reload the whole model, so I would try that first.
If all else fails you can still use Repository.OpenFile (string Filename) to completely reload the model.
