Author Topic: Accessing Stereotypes via VBscr: Strange behaviour  (Read 3737 times)
Illo
« on: December 18, 2010, 02:39:15 am »
I observed a strange behaviour of EA while setting and reading multiple stereotypes of a UML class:
If I set two stereotypes via the properties dialog, the script reads only one of them.
If I set multiple stereotypes via script and try to read them afterwards, only one or two of them will be read depending of the call of theElement.Update.
It seems to me that the bahaviour of EA is not reliable.
Does anyone encountered the same problems and does have a good explanation for this behaviour?
Perhaps EA is not really designed for assigning more than one stereotypes to elements? I have no idea.
Oliver
PS: I'm working here with EA 8.0.861 CE
Here's my code for testing:
option explicit
!INC Local Scripts.EAConstants-VBScript
' Script Name: AccessStereotypes
' Author: Oliver Roeke
' Purpose: Test the access to stereotypes
' Date: 17.12.2010
sub main
      Session.Output( "AccessStereotypes" )
      Repository.EnsureOutputVisible "Script"
      ' Get the currently selected element in the tree to work on
      dim theElement as EA.Element
      set theElement = Repository.GetTreeSelectedObject()
      if not theElement is nothing and theElement.ObjectType = otElement then
            ' Try to read multiple stereotypes which have been set via element's property dialog.
            ' Expected result: utility,type
            Session.Output( "Stereotypes of " & theElement.Name & ": " & theElement.Stereotype )
            ' System behaviour: utility -> type missing -> bug
            ' Try to set multiple stereotypes tread,utility via script
            theElement.Stereotype = "thread,utility"
            theElement.Update
            ' Try to read them:
            ' Expected result: tread,utility
      end if
end sub
main
Illo
Re: Accessing Stereotypes via VBscr: Strange behav
« Reply #1 on: December 18, 2010, 03:09:11 am »
Hello @ all,
I found the bug.
Accoding to the basic law of software engineering:
"If debugging is the process of removing bugs, programming must be the process for putting them in."
I'm responsible for the bug:
Replacing '.Stereotype' by '.StereotypeEx' in my coded will solve the problem.
But nevertheless trying to set more than on stereotypes by using the property '.Stereotype' leads to courious behaviour, espacially when combined with setting stereotypes via property dialog.
Greetings,
Oliver
Oliver
option explicit
' Date: 17.12.2010
sub main
            theElement.Update
            ' Try to read them:
      end if
end sub
main
