Author Topic: How to reference a diagram in documentation  (Read 6070 times)
cmars
« on: November 21, 2016, 09:05:06 pm »
Is it possible to reference a named diagram in a text document ?
I only succeed with copy/past command.
Should I have to use template and filters to do this ?
Is there someone have some examples ?
PeterHeintz
Re: How to reference a diagram in documentation
« Reply #1 on: November 21, 2016, 09:58:12 pm »
What exactly do you mean about this?
And what do you expect from the reference?
In text you have in EA, you can add a link within the text to any element, including diagrams.
Best regards,
Peter Heintz
cmars
« Reply #2 on: November 21, 2016, 11:37:19 pm »
I would like to insert a diagram into a document without using the cut/paste because
I want my document updated when the EA model had been updated!
PeterHeintz
« Reply #3 on: November 22, 2016, 01:14:09 am »
What is a document for you?
E.g. just a MS-Word file you edit manually or a WS-Word file you generated from EA or a ...????
Best regards,
Peter Heintz
cmars
« Reply #4 on: November 22, 2016, 01:27:14 am »
Yes it is just a text document like MS-Word file.
PeterHeintz
« Reply #5 on: November 22, 2016, 01:43:17 am »
Well, when I need a document I do entirely generate that from EA, so I have no experience about that, but maybe this can help you: http://www.sparxsystems.com/products/mdg/int/office/office-integration.html
Best regards,
Peter Heintz
« Reply #6 on: November 22, 2016, 03:31:46 pm »
I think you should look into the standard document generation facilities, or look at eaDocX.
The latter has a refresh, whereas with the first you have to generate the whole document from scratch again.
