Author Topic: Images cropped in generated document  (Read 11417 times)
« on: November 22, 2016, 12:38:12 pm »
Has anyone observed an issue like this where images are truncated/cropped in a generated document
Build 1307, images are included using a diagram fragment.
Re: Images cropped in generated document
« Reply #1 on: November 22, 2016, 03:32:56 pm »
Yes,
A colleague of mine "sometimes" has the same problem.
We haven't been able to pinpoint when exactly this happens.
« Reply #2 on: November 24, 2016, 08:42:19 am »
I'm extremely pleased to find this fixed in build 1308, just saved me putting in a fault report.
cgreuter
« Reply #3 on: February 22, 2017, 11:23:21 pm »
It does not seem to be fixed in the current build. I have the same issue that Diagram images are cut when i create reports or publish diagrams as images...
It is extremely inconvenient, but i found that a compure restart sometimes helps (perhaps thats by accident)
Any ideas?
« Reply #4 on: September 14, 2018, 09:03:08 am »
I'm seeing this in V14. I'm sure I've seen a post about changing some configuration thats cures this, but I can't locate it.
Any ideas?
« Reply #5 on: June 05, 2019, 01:49:18 am »
I see the same issue in the 13.0.1310 build 1310 Registered Enterprise Architect (Corporate Edition).
I think this is somewhat related to conflicts to my Dell laptop Windows 10 screen resolving, but this is just the guess.
My observation is the following:
 1. I was working with the 1360x768 resolution in Windows "Display settings" (right click desktop, you know)
   Why I did that? Not sure, I think at some point it seemed a good font size to my eye ...
   With this setting the EA generated cropped images.
   I also noticed, that when I add an element to a diagram, the EA changes resolution of the screen shortly, then renders it back to selected setting.
 2. I think when in the office with external screen the issue was gone (I will reconfirm ...)
 => These two facts brought me to idea of playing with screen resolution.
 => I opened Windows "Display settings" again, and looked for the resolution marked "(recommended)"
  That was of course the highest 1920x1080 (Recommended)
  The font scale changed to 150% (Recommended) automatically
=> I generated the doc again, bingo! the images are no cropped anymore.
magic?!
I think this fits to Geerts "A colleague of mine "sometimes" has the same problem."
and to the cgreuters "... i found that a compure restart sometimes helps (perhaps thats by accident)"
observations
As promissed, I tested Doc.Generation in the office setup with 2 displays in extended screen. The generation worked in recommended setup without cropping images. Also when I changed both displays to 1360x768 I could generate documentation without cropping images. For me this means, the trouble happens at least when single laptop display is used in some strange from Windows/EA point of view display congfiguration.
Summary: I cannot really confirm that I found the solution, but rather a hint direction how to avoid image cropping in documentation.
Appreciate any sharing info from the community.
« Last Edit: June 05, 2019, 04:58:52 pm by [email protected] »
steen.jensen
« Reply #6 on: June 07, 2019, 07:09:50 pm »
Im using EA 14.27 and somtimes the right line from the Diagram frame is croped.
I now using a 1 cell table that the diagram is placed inte report template.
Now I can resize the 1 cell table as I want and the diagram is then resized inside that table.
Mats Gejnevall
« Reply #7 on: September 29, 2020, 11:34:07 pm »
The images in my generated document is being cropped in v15.1
Any ideas?
Mats
steen.jensen
« Reply #8 on: September 30, 2020, 08:38:07 am »
Default settings in EA is NOT to scale to page. :(
I set in preferens Scale to 1 Page A4 Landscape as default, and Change on each diagram that needs scale to Portrate
