Author Topic: BPMN Template Elements don't honour the element size  (Read 7588 times)
Graham_Moir
« on: November 25, 2016, 04:31:25 am »
Version 13.  I have set the style attributes on a BPMN activity element in a template package and also resized the element.   When a new BPMN activity is added to a diagram,  EA picks up the style OK, but the default old size of the element seems to dominate.   I see a quick flash where the revised template element dimensions appear, but they immediately disappear to be replaced with the default much smaller size.   I assume this is because BPMN's origins in EA is as an MDG addin, although it is now delivered as standard by default with EA.
Would you call this a bug?  Is it even fixable?
Re: BPMN Template Elements don't honour the element size
« Reply #1 on: November 25, 2016, 10:38:32 am »
Hi Graham,
It seems to be a generic MDG problem.  I've seen and complained about it in other posts.  If you use Browser Add Element...  You'll get a different outcome to dragging off the toolbar.  You can even set the value in the shape script and it will be overridden - as you note, having first "teasingly" displayed the "correct" shape.  It's a bug, ...
Graham_Moir
« Reply #2 on: November 28, 2016, 09:10:06 pm »
Thanks Paolo.  I'm sure you've reported it, but I will too.
Graham_Moir
« Reply #3 on: November 30, 2016, 08:31:17 pm »
Reported with the reply from Sparx of "This has been confirmed to be fixed in a future build."
« Reply #4 on: December 01, 2016, 10:38:34 am »
Thanks, Graham!
