Author Topic: Exporting to Excel  (Read 14280 times)
Marcelino Placeres
Exporting to Excel
« on: January 26, 2017, 02:22:54 am »
Hi there,
Can a package/diagram be exported to Excel in way that allows to manipulate the resulting data? For example, I wonder if the resulting data (Excel file) can be filtered, manipulated and transformed.
Thank you in advance,
Marcelino
Re: Exporting to Excel
« Reply #1 on: January 26, 2017, 04:24:16 am »
Look for CSV import/export in the help.
Marcelino Placeres
« Reply #2 on: January 26, 2017, 04:38:05 am »
Hi Geert,m
I checked the CSV import/export in the help. I "tested" the options described there. But EA doesn't export the Excel file with data that can be manipulated afterwards. That's why I'm asking if anyone had a solution for this requirement.
Thank you,
Marcelino
« Reply #3 on: January 26, 2017, 03:16:41 pm »
Marcelino,
What do you man "cannot be manipulated afterwards"?
We've done that a quite often, export to CSV, manipulate the data in excel, and import back into EA.
Marcelino Placeres
« Reply #4 on: January 26, 2017, 11:55:16 pm »
For example, we would like to be able to "manipulate or transform" the data with the PowerPivot add-in, Filtering data, etc.
« Reply #5 on: January 27, 2017, 03:53:36 pm »
You can manipulate all you want, just make sure you save the data as CSV in exactly the same order you originally exported it.
« Reply #6 on: January 27, 2017, 11:15:26 pm »
Hi Marcelino Placeres
For exporting datas into excel and manipulate then to resynch to EA , you could use Enterprise Architects MDG Integration for Microsoft Office .
Nabil
    • View My LinkedIn Profile Here
« Reply #7 on: January 30, 2017, 07:54:50 pm »
As Arshad mentioned you can try this MDG for Office tools
http://www.sparxsystems.com/products/mdg/int/office/office-integration.html
I use it often to export data and to re-work on my excel and sync back to EA.
It is quite easy too.
Nabil
