Author Topic: BPMN Import  (Read 5757 times)
Marianne
BPMN Import
« on: February 08, 2017, 12:52:42 am »
when I try to import BPMN, the strip GUID is checked and read only. This means that ID's are overwritten.
What do I have to do to be able to keep the id's from the imported BPMN?
Thanks!
Kind Regards,
Marianne
Re: BPMN Import
« Reply #1 on: February 08, 2017, 02:20:16 am »
Strip GUID means that EA creates new GUIDs for the elements and thus does not match it against existing elements. Be sure to have it unchecked in order to replace rather than create new elements on import.
Marianne
Re: BPMN Import
« Reply #2 on: February 08, 2017, 02:45:03 am »
That is the problem: I can't uncheck the field because it is read-only. Why is it read-only?
Re: BPMN Import
« Reply #3 on: February 08, 2017, 03:10:12 am »
That checkbox will only work for importing xmi that was generated by EA in the first place.
It won't do any good for other formats.
VKN
Re: BPMN Import
« Reply #4 on: February 08, 2017, 10:05:33 am »
Marianne is talking about BPMN specific importer.
Yes. That option cannot be changed in any case (Informative only).
The BPMN that is being imported doesn't contain enough EA specific information to identify existing elements, even if that BPMN was exported through EA.
No. It always creates new ones.
Nothing. You just can't.
