Author Topic: ShapeScript for BPMN activity  (Read 36093 times)
Re: ShapeScript for BPMN activity
« Reply #15 on: February 15, 2017, 10:53:23 pm »
Check the code for the decoration for example Archimate Business process
if(hastag("showdecoration","true"))
moveto(0,25);
lineto(55,25);
lineto(55,0);
lineto(80,50);
lineto(55,100);
lineto(55,75);
lineto(0,75);
lineto(0,25);
I just tested this and adding a tagged value with name "showdecoration" and value "true" makes the process decoration appear in the top left corner.
Viking
« Reply #16 on: February 16, 2017, 02:06:51 am »
moveto(0,25);
lineto(55,25);
lineto(55,0);
lineto(80,50);
lineto(55,100);
lineto(55,75);
lineto(0,75);
lineto(0,25);
I just tested this and adding a tagged value with name "showdecoration" and value "true" makes the process decoration appear in the top left corner. Geert
Thank you, Geert. My undestanding was that you script has been extracted from EA. And the original script does not ask for the tag, but for the property Archimate property showdecoration. Or is property also a tag? But then the script would have been worked on my computer, because the property is set.
« Reply #17 on: February 16, 2017, 03:07:18 am »
Yes, Archimate properties are also tagged values.
This is really the shapescript that is embedded in the standard Archimate MDG, so if you have the tagged value set to true then the decoration should show.
Viking
« Reply #18 on: February 16, 2017, 05:27:04 am »
Now I understand. Thank you.
I am confused because I have alternate definitions of shapes in my script. Could I write the script like the one below? I cannot imagine, because "decoration" has to be on the top level. But then decoration would affect all shapes. Or would I need to add an if-than statement to the decoration?
shape main
   layouttype="border";
   if(hasproperty("diagram.mdgtype", " BPMN2.0::Business Process "))
      //BPMN
      AddSubShape("Activity","center");
   else
      //ArchiMate as default
      AddSubShape("ProcessStep","center");
   shape Activity
      shape label
      decoration process
   shape ProcessStep
« Last Edit: February 16, 2017, 05:56:02 am by Viking »
« Reply #19 on: February 16, 2017, 06:05:32 am »
I guess you'll have to write the same condition in the decoration as in the main shape to distinguish between one or the other shape.
Viking
« Reply #20 on: February 16, 2017, 07:56:07 pm »
I guess you'll have to write the same condition in the decoration as in the main shape to distinguish between one or the other shape. Geert
O.K. I tried this. But my / our script does not work. It always shows a rounded rectangle with a small rectangle inside the rectangle. And it also changes the colour. I get mad (or schizophrenic). Any ideas, why the script does not work?
shape main
if(hasproperty("diagram.mdgtype", "BPMN2.0::Business Process"))
//BPMN
else
//default (ArchiMate)
//BPMN
shape Activity
if(hasTag("triggeredByEvent","true")) // 99x: 8-4-2011
setlinestyle("dot");
defsize(110,60);
startpath();
roundrect(0,0,100,100,10,10);
endpath();
fillandstrokepath();
if(hasTag("isACalledActivity","true"))
setpenwidth(2);
startpath();
endpath();
if(HasTag("isATransaction","true"))
roundrect(2,3,98,98,10,10);
if(HasProperty("BPMNexpanded","1"))
if(hastag("taskType","Abstract"))
addsubshape("nametopleft","N");
addsubshape("base","S");
addsubshape("padding","W");
addsubshape("padding","E");
addsubshape("comp","CENTER");
else
addsubshape("padding","N");
addsubshape("Name","CENTER"); //BJS C13011371. Added name back to ter so it doesn't overlap
  //icons.
else
addsubshape("Name","CENTER"); //BJS C13011371. Added name back to center so it esn't overlap
  //icons.
shape nametopleft
h_align = "left";
Printwrapped("#NAME#");
shape comp
DrawComposedDiagram();
shape name
layouttype = "border";
h_align = "center";
//BJS C13011371.
if(hasproperty("ShowComposedDiagram", "true"))
addsubshape("padding", "N");
addsubshape("Comp", "CENTER");
shape padding
preferredHeight = 35;
shape comp
shape padding
preferredHeight=20;
preferredWidth=6;
shape base
preferredHeight=20;
addsubshape("null","N");
addsubshape("null","S");
addsubshape("baseshapes","CENTER");
shape null
preferredHeight=3;
shape baseshapes
layouttype="leftright";
scalable=false;
v_align="CENTER";
h_align="CENTER";
addsubshape("spacer");
if (HasTag("loopCharacteristics","Standard"))
addSubShape("loop");
if (HasTag("loopCharacteristics","MultiInstance"))
if(hasTag("isSequential","false"))
addSubShape("parallelMultiple");
else
addSubShape("sequentialMultiple");
if (HasTag("isForCompensation","true"))
addSubShape("compensation");
if (HasTag("activityType","Sub-Process"))
if(HasProperty("ShowComposedDiagram", "false"))
else
addSubShape("collapsed");
else
if(HasProperty("iscomposite","true"))
if (HasTag("adHoc","true"))
addSubShape("adhoc");
//Sharon C12111022: Do not render any shape for "adHocOrdering" ng.
//Sharon C14033070: remove the redundant code for ocOrdering"
shape spacer
preferredWidth=2;
shape loop
preferredWidth=15;
preferredHeight=15;
setpenwidth(2);
moveto(0,90);
//bezierto(-80,-30,170,-30,80,100);
//Sharon C11128881: Use arc() to render Loop shape.
moveto(70,90);
arc(0,0,100,100,70,90,30,90);
setfillcolor(getuserbordercolor());
startpath();
moveto(-20,100);
lineto(40,100);
lineto(40,60);
endpath();
fillpath();
shape sequentialMultiple
preferredWidth=15;
preferredHeight=15;
startpath();
rectangle(0,10,100,25);
endpath();
startpath();
rectangle(0,42,100,63);
endpath();
startpath();
rectangle(0,80,100,95);
endpath();
shape parallelMultiple
preferredWidth=15;
preferredHeight=15;
startpath();
rectangle(10,0,25,100);
endpath();
startpath();
rectangle(47,0,58,100);
endpath();
startpath();
rectangle(80,0,95,100);
endpath();
shape compensation
preferredWidth=15;
preferredHeight=15;
setfillcolor(getuserfillcolor());
startpath();
moveto(0,50);
lineto(50,0);
lineto(50,100);
endpath();
startpath();
moveto(50,50);
lineto(100,0);
lineto(100,100);
endpath();
shape collapsed
preferredWidth=15;
preferredHeight=15;
rectangle(0,0,100,100);
moveto(15,50);
lineto(50,50);
moveto(85,50);
lineto(50,50);
moveto(50,15);
lineto(50,50);
moveto(50,85);
lineto(50,50);
Shape adhoc
preferredWidth=15;
preferredHeight=15;
SetPenWidth(3);
MoveTo(0,50);
StartPath();
PolyBezierTo(50,0,50,100,100,50);
EndPath();
StrokePath();
shape ProcessStep
v_align="center";
h_align="center";
if(hasproperty("rectanglenotation","0"))
defsize(90,40);
startpath();
moveto(0,0);
lineto(75,0);
lineto(75,-30);
lineto(100,50);
lineto(75,130);
lineto(75,100);
lineto(0,100);
lineto(0,0);
endpath();
else
defsize(105,70);
roundrect(0,0,100,100,20,20);
addsubshape("padding","n");
addsubshape("name","center");
shape padding
preferredheight=20;
shape name
h_align="center";
print("#name#");
//BPMN Decoration
decoration TaskType
orientation="nw";
layouttype="topdown";
if(hastag("activityType","Task"))
if(hastag("taskType","Send"))
setpencolor(getuserfillcolor());
rectangle(0,0,100,90);
setpenwidth(2);
moveto(0,0);
lineto(50,50);
lineto(100,0);
if(hastag("taskType","Receive"))
if (hastag("instantiate","true")) //30/03/2011
ellipse(0,0,100,100);
rectangle(20,20,75,70);
moveto(20,20);
lineto(50,50);
lineto(75,20);
else
moveto(0,0);
lineto(50,50);
lineto(100,0);
if(hastag("taskType","BusinessRule"))
rectangle(0,0,120,90);
setfillcolor(192,192,192);
rectangle(0,0,120,20);
moveto(30,20);
lineto(30,90);
moveto(0,57);
lineto(120,57);
if(hastag("taskType","Script"))
moveto(20,0);
lineto(90,0);
bezierto(50,40,110,55,90,100);
lineto(20,100);
bezierto(50,55,-10,40,20,0);
moveto(25,20);
lineto(60,20);
moveto(23, 40);
lineto(67,40);
moveto(30,60);
lineto(68,60);
moveto(35,80);
lineto(72,80);
if(hastag("taskType","Manual"))
moveto(0,80);
lineto(10,100);
lineto(80,100);
bezierto(85,100,95,90,80,85);
lineto(65,85);
moveto(80,85);
lineto(85,85);
bezierto(90,85,104,78,85,70);
lineto(60,70);
moveto(65,70);
lineto(90,70);
bezierto(90,70,115,56,75,55);
lineto(60,55);
moveto(65,55);
lineto(85,55);
bezierto(95,57,135,37,60,40);
lineto(40,40);
moveto(55,40);
bezierto(70,40,70,20,60,25);
lineto(10,25);
lineto(0,40);
if(hastag("taskType","User"))
moveto(38,50);
bezierto(14,56,5,56,0,85);
lineto(0,100);
lineto(100,100);
lineto(100,85);
bezierto(95,58,86,58,62,50);
moveto(38,45);
lineto(38,55);
lineto(62,55);
lineto(62,45);
moveto(30,90);
lineto(30,100);
moveto(70,90);
lineto(70,100);
moveto(64,50);
//Sharon C11128881: use arc() replace bezierto().
//bezierto(115,-20,-15,-20,40,47);
arc(25,0,75,50,64,50,38,49);
setfillcolor(0,0,0);
startpath();
moveto(64,25);
arcto(25,0,75,50,64,25,38,25);
lineto(64,25);
endpath();
if(hastag("taskType","Service"))
addsubshape("sub1",125,125,25,28);
addsubshape("sub2",125,125,-6,-130);
shape sub1
layouttype = "leftright";
moveto(79,55);
lineto(100,55);
lineto(100,45);
lineto(79,45);
arc(20,20,80,80,78,45,75,32);
moveto(75,32);
lineto(89,18);
lineto(82,11);
lineto(68,25);
arc(20,20,80,80,68,25,56,20);
moveto(56,20);
lineto(55,20);
lineto(55,0);
lineto(45,0);
lineto(45,20);
//up-left
arc(20,20,80,80,45,20,33,25);
moveto(33,25);
lineto(19,11);
lineto(11,19);
lineto(25,33);
arc(20,20,80,80,25,33,20,45);
moveto(20,45);
lineto(0,45);
lineto(0,55);
lineto(20,55);
//down-left
arc(20,20,80,80,20,55,25,67);
moveto(25,67);
lineto(11,82);
lineto(19,89);
lineto(33,75);
arc(20,20,80,80,33,75,45,80);
moveto(45,80);
lineto(45,100);
lineto(55,100);
lineto(55,80);
//down-right
arc(20,20,80,80,55,80,67,75);
moveto(67,75);
lineto(82,89);
lineto(89,82);
lineto(75,67);
arc(20,20,80,80,75,67,79,55);
addsubshape("middle", 50,50,23,24);
shape middle
moveto(79,55);
lineto(100,55);
lineto(100,45);
lineto(79,45);
moveto(75,32);
lineto(89,18);
lineto(82,11);
lineto(68,25);
moveto(56,20);
lineto(55,20);
lineto(55,0);
lineto(45,0);
lineto(45,20);
//up-left
moveto(33,25);
lineto(19,11);
lineto(11,19);
lineto(25,33);
moveto(20,45);
lineto(0,45);
lineto(0,55);
lineto(20,55);
//down-left
moveto(25,67);
lineto(11,82);
lineto(19,89);
lineto(33,75);
moveto(45,80);
lineto(45,100);
lineto(55,100);
lineto(55,80);
//down-right
moveto(67,75);
lineto(82,89);
lineto(89,82);
lineto(75,67);
shape sub2
v_align="CENTER";
h_align="CENTER";
moveto(75,32);
lineto(89,18);
lineto(82,11);
lineto(68,25);
moveto(56,20);
lineto(55,20);
lineto(55,0);
lineto(45,0);
lineto(45,20);
//up-left
moveto(33,25);
lineto(19,11);
lineto(11,19);
lineto(25,33);
moveto(20,45);
lineto(0,45);
lineto(0,55);
lineto(20,55);
//down-left
moveto(25,67);
lineto(11,82);
lineto(19,89);
lineto(25,83);
//default decorations (ArchiMate)
decoration process
orientation="ne";
else
else
moveto(0,25);
lineto(55,25);
lineto(55,0);
lineto(80,50);
lineto(55,100);
lineto(55,75);
lineto(0,75);
lineto(0,25);
decoration atomic
orientation="nw";
else
if(hastag("atomic","true"))
moveto(20,80);
lineto(50,20);
lineto(80,80);
moveto(35,50);
lineto(65,50);
decoration composite
orientation="SE";
else
if(hasproperty("iscomposite","true"))
ellipse(0,40,40,60);
ellipse(60,40,100,60);
moveto(30,50);
lineto(70,50);
Viking
« Reply #21 on: February 17, 2017, 12:12:47 am »
It works now. But a new issue arose. That's why I started a new thread. As soon as the script works properly I will publish it in ths thread.
Viking
« Reply #22 on: February 20, 2017, 02:01:46 am »
The proplem has been solved. I missed a bracket. The correct code can be found in "ShapeScript - conditional setting of variables" http://sparxsystems.com/forums/smf/index.php/topic,37909.0.html.
Thank you all for your valuable input.
« Last Edit: February 20, 2017, 02:11:15 am by Viking »
