Author Topic: Protecting some MDG  (Read 8133 times)
adepreter
Protecting some MDG
« on: March 09, 2017, 08:47:32 pm »
If we want to make a product out of an MDG, what is the best way to protect it from reverse engineering?
- MDG as part of the database?
- MDG as part of an add-on?
Thank you in advance
A.
Uffe
Re: Protecting some MDG
« Reply #1 on: March 09, 2017, 09:21:06 pm »
It's a question of how protected you want it, and from whom. Absolute protection is impossible.
There is no built-in EA function to reverse-engineer an MDG Technology file, which provides protection against the idly curious.
The file format is undocumented, which provides some additional protection against undetermined tinkerers.
But the format is pretty simple to work out, so there is no protection from someone who is sufficiently knowledgeable and/or determined.
So the highest level of protection you can implement I guess would be to distribute the MDG Technology in encrypted form as part of an Add-In and injecting it into the database directly when a project is opened, bypassing Repository.ImportTechnology() since that requires the MDG Technology to be located in an unencrypted file.
But that's still no protection against those with a detailed knowledge of EA.
/Uffe
« Reply #2 on: March 10, 2017, 02:26:11 am »
The question is whether or not it is even worth protecting.
All of my work is open source, so everyone can use whatever scripts or addins I produce; where's the harm?
Making things open source even yielded more work (and thus profit) then trying to protect it.
« Reply #3 on: March 10, 2017, 03:05:20 pm »
Unencrypt the technology and return the resulting string to EA_OnInitializeTechnologies. The result is that it's never stored in a file, which is protection against everyone not used to debugging without the source code.
