Author Topic: VBScript - Remove duplicate elements from arraylist  (Read 15200 times)
MatthiasVDE
« on: March 10, 2017, 04:26:06 am »
Is it possible to remove duplicate elements from an arraylist?
I tried with some functions but no success.
'returns an ArrayList without duplicates
function removeDuplicates(arraylist)
dim result
set result = CreateObject("System.Collections.ArrayList")
dim element as EA.Element
for each element in arrayList
dim b
b = contains(arraylist, element)
'if contains then
'else
'end if
next
set removeDuplicates = result
end function
'returns boolean
function contains(arraylist, element)
set contains = false
dim res as EA.Element
for each res in arrayList
if res.ElementID = element.ElementID then
set contains = true
exit for
end if
next
end function
Re: VBScript - Remove duplicate elements from arraylist
« Reply #1 on: March 10, 2017, 06:15:25 am »
You have to iterate backwards through the arraylist and then keep a second arraylist (or dictionary) with the one that you have already encountered.
If you then have a duplicate you can remove it safely from the arraylist.
Another option is to make a new arraylist (or dictionary) object and add only the unique ones.
There are some examples of deleting elements from a list in the VBScript library
MatthiasVDE
« Reply #2 on: March 10, 2017, 06:13:48 pm »
I found it:
dim result
dim b
b = contains(result, element)
if b = false then
result.add(element)
end if
next
end function
'returns boolean
function contains(result, element)
contains = false
for each res in result
contains = true
exit for
end if
next
end function
