Author Topic: Copy/Paste and crash issues  (Read 11985 times)
SabbeRubbish
« on: March 16, 2017, 01:46:14 am »
Hi all,
Have been using Sparx EA for quite some time, but since v13 I'm running into issues.
The most frustrating one is that if I create a basic UML diagram, see sparx3.png and I select all (using CTRL+A) and I copy (using CTRL+C), then the contents on the clipboard are not complete, the image is cropped to the right and to the bottom. This never happened before.
See sparx4.png for a simple paste operation in Paint. Note that I have tried other applications like Word, PowerPoint, ... It's always cropped, doesn't have anything to do with Paint itself.
I must also state that sometimes when I unplug and plug an external monitor to my laptop (or it goes to sleep) Enterprise Architect crashes for some reason, don't know why, but it may be related.
Sparx4.png:
Thanks in advance for any help in the right direction! :-)
SabbeRubbish
Re: Copy/Paste and crash issues
« Reply #1 on: March 22, 2017, 02:31:51 am »
It seems like the issue no longer occurs (luckily).
« Reply #2 on: March 22, 2017, 08:59:32 am »
For the truncated images, is EA set to use bitmaps or metafiles on the clipboard? (Start | Workspace | Preferences | General)
The crash sounds a lot like reports that we had about Windows 10. Check if you're on the latest build, I believe it was fixed in 1310.
« Reply #3 on: January 18, 2018, 10:54:10 pm »
Hi all,
Hi SabbeRubbish
I know no one cares about this item now  ;) ;) An workaround for this issue.
Instead of copying and pasting diagram into powerpoint would you considered using PowerPoint Extension of Enterprise Architect (includes in  MDG Office Integration ).
You can export diagrams directly from EA to powerpoint by a single click.
Refer below link for more details
https://www.sparxsystems.in/blogs/sparx-systems-enterprise-architect-publish-model-contents-to-powerpoint-presentations/
« Last Edit: January 18, 2018, 10:57:27 pm by EAUser3200 »
PJK
  • Transmisi me sursum, Caledoni
« Reply #4 on: January 24, 2018, 02:44:07 am »
CTRL-B copies the diagram image to the clipboard. I have never had any problems with that.
Cheers, Phillip
dnemiro1
« Reply #5 on: January 26, 2018, 01:02:57 pm »
I am running v13.5 and have the same issue, however I wonder if it is a MSFT Windows 10 Issue.
When I copy diagrams using the clipboard to PowerPoint, e-mail, etc. much is cropped off.
A system reboot solves the problem for a few days then it happens again.
However, a clipboard problem I have had since EA v10 is the document is copied with 30% more right and bottom margin leaving too small an image.
-DN
EdK
« Reply #6 on: March 01, 2018, 01:15:45 am »
When I try to copy a diagram to the clipboard with format Metafile and then paste into MS Word or Paint only one or two elements in the diagram are copied. But when I switch format to bmp the copy-paste works just fine.
The quality of the BMP image does not appear to be as good as Metafile so I would like to figure out how to get the clipboard copy feature working with Metafile.
Any suggestions would be appreciated.
EA Ultimate Edition Version 12.1.1228
MS Windows Server 2012 R2
R/S Ed K
(EA Ultimate Edition Version 12.1.1228)
« Reply #7 on: March 01, 2018, 02:32:34 am »
Try saving the diagram and then use it.
Cntrl + T ( Shotrcut for saving diagram ) .
« Last Edit: March 01, 2018, 02:38:07 am by Arshad »
EdK
« Reply #8 on: March 01, 2018, 06:26:13 am »
The diagram was saved and saved again but same results. Other ideas?
R/S Ed K
dnemiro1
« Reply #9 on: May 11, 2018, 07:59:48 am »
My opinion is that this is a memory leak in EA.  In EA10-13 I noticed that if I reboot the bug goes away for a little while, then comes back.
In EA14, which I just installed 2 days ago, it seems to be fixed.  However, EA14 still seems to have a bug where too much white space is copied.
Takeshi K
    • Sparx Systems Japan
« Reply #10 on: May 12, 2018, 08:46:46 am »
Hi all,
One of my customer faced the same issue, and the reason is DPI is not 100%.
If DPI is 100%, this issue does not happen. But if 125% or 150%, it happens on some machines.
t-kouno
