Author Topic: Connector Labels and Dotted Line styles  (Read 3484 times)
« on: June 21, 2017, 05:33:04 pm »
I'm sure I've reported this over the decade or so, but I can't find it in the search.
If you create a label for a connector (such as add name of Association), if the line is a Solid line, then the text of the label can be positioned so that it overrides the line and you can CLEARLY see the text.  However, if the line is one of the non-solid (setlinestyle()) lines, then the underlying line will "peek" through - making the text unreadable.  Can this be fixed, please?
Report,
