Author Topic: Diagrams in report cropped again!  (Read 13968 times)
michielper
« on: September 04, 2017, 10:33:58 pm »
Again! For no apparent reason, the diagrams in my reports are printed incompletely: They are cropped so that large parts of the diagrams on the right side and underside are invisible! I am not aware of having changed any relevant settings and this is a very serious impediment to my work!
Any help is greatly appreciated!!
« Last Edit: April 20, 2018, 06:23:04 pm by michielper »
Glassboy
Re: Diagrams in report cropped!
« Reply #1 on: September 05, 2017, 07:11:29 am »
Suddenly, for no apparent reason, the diagrams in my reports are printed incompletely: They are cropped so that large parts of the diagrams on the right side and underside are invisible! I am not aware of having changed any relevant settings and this is a very serious impediment to my work!
I'm guessing you had scale to 1 page on, and now you've turned it off.  BTW I think you mean "bottom", the underside is easily printed on by turning duplexing on in your printer settings.
michielper
Re: Diagrams in report cropped! - Resolved
« Reply #2 on: September 05, 2017, 07:11:46 pm »
Glassboy, thanks for the help. But today my problem has magically disappeared without having changed any settings..... Diagrams are now shown in the reports as before. Completely weird behavior, probably due to Windows...  ;). The issue had nothing to do with the documentation template I used and neither with the particular model since it occurred also when I created a new model and used a standard template. It happened also with small diagrams that easily fit on one page; they were cut off at the right and lower side to a size of less than 10x10 cm.
But everything is back to normal now. So the advice to anyone experiencing the same problem is: do nothing and try again tomorrow....:).
natvig
« Reply #3 on: September 06, 2017, 04:36:07 am »
I have noticed similar behaviour when using EA from within a virtualised windows environment (like Parallels on Mac). Depending on the resolution set on the Windows desktop the images are cropped to a larger or lesser extent. Before generation of final documentation I sometimes need to change resolution.
/Hans
Mauricio Moya (Arquesoft)
    • Arquehub Azure Module
« Reply #4 on: September 08, 2017, 02:45:49 am »
I have experimented similar behavior (overlapping of diagrams on text) when creating the report in PDF format. If created in RTF and open with the internal viewer the diagrams are shown right.
Heidi V.
Re: Diagrams in report cropped again!
« Reply #5 on: October 02, 2021, 01:16:27 am »
I experienced the same behaviour today. It may have a relation to the fact that first I had a model open while my computer was not in its docking station, I still had it open when I connected to the docking station. The generated file had cropped images. When closing EA and opening the project file again, the problem disappeared...
jami
  • ekhm
« Reply #6 on: October 05, 2021, 11:54:43 pm »
This is not cutting out, but you may have had a similar case: When you zoom in and out of diagrams in a generated document, the diagrams turn black and white or disappear and the document freezes. It could be EA's or Word's fault?
Sunshine
  • Its the results that count
« Reply #7 on: October 08, 2021, 08:37:37 am »
There was another post on this topic and it was suggested that changing the image format might help. IIRC it was change PNG to BitMap. Seemed to fix the issue for me.
Happy to help
