Author Topic: how to call an add-in when a element is added and any element values changed  (Read 10808 times)
vignesh
I have created an add-in and  added it to EA and its working fine and now i need to call the add-in when element is add or values of the element changed .If this is possible via trigger could you please give me a brief steps about how to do it.
Thanks in Advance.
EA will send out broadcasts when certain actions take place, so you need to create functions that respond to those broadcasts. For example, to respond to a new element being created, you will need to have a function called EA_OnPostNewElement. Search the help for "EA_OnPostNewElement" and it should point you in the right direction.
vignesh
Thanks!!
Its really helpful..
I need to keep hold of the currently added element.Could you please help how to get it.
Thanks in Advance.
If you read the link for the operation KP mention you should know.
vignesh
I am getting index out of range error  when i use the broadcast function as mentioned above.Is there any work around or direct solution for it?
Thanks in advance.
Without knowing what you have done there I would need to look into my glass bowl. Unfortunately I had to send it in for maintenance yesterday.
Helmut Ortmann
I would do:
- Check passed variables for 0/null
- Check variables for its values before using them
- Use a try {} catch {} block to handle exceptions
- Switch to DEBUG mode or use debug messages
Best regards,
Helmut
vignesh
I have written the below mentioned code in EA_OnPostNewElement function and the error index out of range is prompted.
 ElementID = int.Parse(info.Get("ID").Value);
 DiagramID = int.Parse(info.Get("DiagramID").Value);
It's a long time since I wrote an add-in, but I don't think you're going to be passed a DiagramID in the EventProperties of EA_OnPostNewElement. Try getting the size of the EventProperties then loop through with Get(index) and see what's there - more reliable than guessing the property names.
« Last Edit: September 27, 2017, 03:09:30 pm by KP »
There's no need to guess. The property names are all documented in the manual; you just have to read it.
Re: how to call an add-in when a element is added and any element values changed
« Reply #10 on: September 27, 2017, 04:04:20 pm »
Correct. I've just checked it's neither "ID" nor "DiagramID".
vignesh
« Reply #11 on: September 27, 2017, 06:37:49 pm »
I need to get the name,type and etc from the newly created element in the EA_OnPostNewElement function is the possible??
Thanks in advance.
« Reply #12 on: September 27, 2017, 06:46:40 pm »
yes
vignesh
« Reply #13 on: September 27, 2017, 08:26:28 pm »
How to fetch it?
Thanks in advance.
« Reply #14 on: September 27, 2017, 08:41:34 pm »
How to fetch it?
Thanks in advance.
Sorry vignesh, you'll have to find another victim to send you teh codez.
I'm not playing.
