Author Topic: Sorting of a Model View?  (Read 6941 times)
anderspe
« on: October 19, 2017, 11:51:20 pm »
I have created a Model View which lists all elements of a specific stereotype but I am not able to sort the list in alphabetical order?
/Anders Pettersson
Glassboy
Re: Sorting of a Model View?
« Reply #1 on: October 20, 2017, 07:54:14 am »
If your question is "Am I able to sort alphabetically in a model view" then I believe the answer will be "yes you can".  You'll need some kind of ORDER BY in the SQL statement.
anderspe
« Reply #2 on: October 20, 2017, 05:28:18 pm »
Yes, my question are: Am I able to sort alphabetically in a model view?
I am using the Query Builder to setup the search and there is no function to define the sort order (as far as I have found)! Anyway  when I run the Search (Give me all elements of a specific Stereotype) the result displayed in the Search function is sorted alphabetically! When I am running the same search by the use of a model view the order in the model view seems to be random!?
Do I really need to use SQL in this case? I have no knowledge of the EA database structure and very limited knowledge of SQL!?
/Anders
« Reply #3 on: October 20, 2017, 06:54:51 pm »
Using SQL is the only way out, I guess. Or you have to send a feature request to pimp the Query Builder. They are anyway working in that area since the order triangle for the columns needs a fix.
Glassboy
« Reply #4 on: October 24, 2017, 07:37:40 am »
Post the SQL query from the model view and what attribute you want to search by and I'm sure someone can show you what to do.
« Reply #5 on: October 24, 2017, 08:18:04 am »
The query builder has two (actually 3 with the add-in) modes where one does not show/need SQL. That part will not accept an ORDER BY.
