Author Topic: Trouble adding a Custom Window to an Addin  (Read 18032 times)
priombiswas89
Re: Trouble adding a Custom Window to an Addin
« Reply #15 on: December 04, 2020, 12:01:27 am »
You reference "PackageListGrid.UserControl"
But your class is called UserControl1
What EA does is use that string to find the COM reference in the registry.
The registry will then tell EA where to find the dll to use to load this class.
Since this string is not found in the registry, EA can't create your control.
It worked, many thanks.
