Author Topic: Efficient scripting alternative for #Branch#  (Read 26151 times)
chrislro
Re: Efficient scripting alternative for #Branch#
« Reply #15 on: October 13, 2023, 11:42:31 pm »
I finally came up with writing a JScript based on multiple inputs seen in this forum. Seems to work, but I just made same quick tests. Just in case someone needs it ...
 * Get the package ids of the given package tree (string = like #BRANCH# in search window).
 * https://sparxsystems.com/forums/smf/index.php/topic,46180.msg270523.html#msg270523
 * https://sparxsystems.com/forums/smf/index.php/topic,38987.msg259113.html#msg259113
function GetPackageTreeIDArray(package /* : EA.Package */) // return: Array of descandant PackageIDs
if (package == null) return [];
// start with current package
var allPackages = [package.PackageID];
// get all child package IDs
return _GetChildPackageIDs(allPackages, allPackages);
function GetPackageTreeIDString(package /* : EA.Package */) // return: String of descandant PackageIDs like #branch#
var ids = GetPackageTreeIDArray(package)
return "" ? (ids.length == 0) : ids.join(",");
function _GetChildPackageIDs(allPackageIDs /* : Array of PackageIDs */, parentPackageIDs /* : Array of PackageIDs */) // return: Array of PackageIDs
// make sure there is at least a 0 is in
if (parentPackageIDs.length == 0)
parentPackageIDs.push(0);
// get all child package IDs (recursively)
var sqlQuery = "SELECT package.Package_ID FROM t_package package WHERE package.Parent_ID IN (" + parentPackageIDs.join(", ") + ")";
var queryResult = Repository.SQLQuery(sqlQuery);
var childPackageIDs = XMLGetNodeTextArray(XMLParseXML(queryResult), "//Row/Package_ID");
allPackageIDs = allPackageIDs.concat(childPackageIDs);
if ( childPackageIDs.length > 0)
allPackageIDs = _GetChildPackageIDs(allPackageIDs, childPackageIDs);
return allPackageIDs;
