Author Topic: Unlock a Block element  (Read 12307 times)
aguevara
« on: January 18, 2018, 08:33:34 am »
I have created a new model and have an element which is showing as Locked.
I do not recall locking this element and did not intend to lock it, of course.
When I right mouse click on the block in the Project Browser, it does not allow me to delete this element nor to unlock it.
I should also mentioned that I have not enabled security on the model. I looked at unlocking it via SQL to no avail.
Can someone chime in as to how to unlock it OR how to delete it?
I am using version 13.
Thanks.
Angelo
Re: Unlock a Block element
« Reply #1 on: January 18, 2018, 09:42:50 am »
How is it shown as locked? Have you turned on version control?
aguevara
« Reply #2 on: January 18, 2018, 10:47:34 am »
It is shown with a red exclamation mark.
I don't think I turned version control on. How can I check?
Thanks.
VKN
« Reply #3 on: January 18, 2018, 11:45:31 am »
How exactly is EA not allowing you?
Is the lock/delete menu disabled or doesn't appear or does it throw an error?
« Reply #4 on: January 18, 2018, 03:30:55 pm »
You have probably turned on security, and someone else locked that element.
Search for "Manage Locks" to be able to remove the lock.
Nabil
    • View My LinkedIn Profile Here
« Reply #5 on: January 18, 2018, 08:28:02 pm »
If the element locked by someone then it will be notified using Red Exclamation
- Try to unlock will say who has locked the element
If Require User lock to edit is enabled then you may not see any icons.
- To Edit/Modify use apply release lock.
Nabil
aguevara
« Reply #6 on: January 18, 2018, 11:31:31 pm »
This model is on my laptop and only accessed by me.
This is the only Element showing a red exclamation mark. At this point, I would just like to remove it.
When I right-mouse click on the block, the "Delete" option is disabled.
I have not enabled Security on this model.
Angelo
Nabil
« Reply #7 on: January 18, 2018, 11:50:22 pm »
If possible share the package some where. Will check it
Nabil
Guillaume
    • www.umlchannel.com
« Reply #8 on: January 19, 2018, 08:36:10 am »
You can lock elements even when the security is not enabled.
Having the locked Block displayed on a diagram, a right click will show "Lock Element" - if the padlock is highlighted it means that the element is locked so you simply need to click on this option (Lock Element).
Guillaume
« Reply #9 on: January 19, 2018, 08:42:42 am »
Guillaume, this will not show the red exclamation mark. It will just disable the OK button in the properties.
PeterHeintz
« Reply #10 on: January 19, 2018, 07:07:30 pm »
What I would try to get rid of that, would be:
An Export/Import or;
an enable/disable of security.
I am not sure if it works but it is worth to give it a try.
Best regards,
Peter Heintz
